Date/Time: Sat, 11 Jan 2025 03:54:28 +0000
Current price line
View Count: 2404
[2016-10-31 11:08:36] |
phaedonk - Posts: 352 |
Is there a way, when Not at the end of the chart, to see the value label of the current price but WITHOUT seeing a price line? I used Current Price Line but could not accomplish that. If I set the line style to Ignore, then the value label also disappears.
[2016-10-31 15:40:46] |
Sierra Chart - Max - Posts: 5778 |
For the Current Price Line study, to hide the line but keep the Name and Value labels set the Display Current Price Line on Chart Bars input to No. Refer to the documentation here on how to Modifying Chart Studies: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support Date Time Of Last Edit: 2016-10-31 15:41:30
[2016-10-31 22:27:43] |
The prior post is incorrect. You need to use this Draw Style: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Display Current Price Line on Chart Bars must be set to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
