Date/Time: Sun, 08 Sep 2024 01:55:38 +0000
GANN SQUARE TOOL
View Count: 2237
[2016-10-31 10:00:00] |
michelh - Posts: 159 |
Hi, the drawing tools on SC are lacking in a basic Gann square tool. The Gann grid just does't cut it. Can you please add a Gann square tool with toggles for the other angles such as the 1/4, 1/3, 1/2, 2/3 and 3/4 lines. I dream of being able to just simple put up a square with a couple of mouse clicks (please see attached screenshot) on the chart instead of having to waste time drawings angles and measuring just to get the same effect. you have a great program, please include this tool which is available on other platforms. also, the option to include a back grid dividing the square into 1/8 increments would be great - also as in the screenshots Date Time Of Last Edit: 2016-10-31 10:01:21
[2016-10-31 19:22:38] |
And if you are kind enough to implement this request, I would like to ask you please to allow the anchor points which are available when you right click a drawing to allow the tool width to be based in number of bars. For example, lets say you want to draw a square of 90 on a daily chart from the 3rd of november. It is a lot easier to say draw 90 bars from the 3rd of November rather than going to a calendar and finding the date that 90 days would land on same for intraday. say you are squaring a range of 20 points on soybean. you want to specify the width as 20 bars instead of calculating times for 20 hours into the future etc. thanks |
[2017-04-16 14:39:44] |
User601045 - Posts: 4 |
Was a Gann Square created??? I'm trying to draw a set of Gann Angles but cant move my hourly chart more than 5 days into the future making my task impossible. Even when I change the date range in chart settings nothing happens. |
[2017-04-16 15:14:16] |
SC empty space on the right is limited to 152 bars in the future. if you have a forecast and need to see further, then you will need to go to higher TF alternatively, they could increase it to say 300 bars |
[2017-04-16 17:11:48] |
Having to plot angles on a daily chart that need to be finely tuned for intraday charts is a real limitation. Thanks for letting me know.
[2017-04-16 20:10:46] |
This is not true. Only rely on Sierra Chart support for accurate information like this. To increase this, refer to: Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-16 20:11:38
