Date/Time: Sat, 11 Jan 2025 03:57:47 +0000
multiple questions
View Count: 806
[2016-10-30 22:22:38] |
User797603 - Posts: 29 |
where is the setting to control what pops up when i right click on my mouse? If I have multi monitors, is it generally better to just have one chartbook open and just detach all the charts to spread out over my window or have a separate chartbooks for each asset? example stocks, futures, market breadth... I am going to need everything open and visible at the same time, that's why i am asking. I am a futures, stock, and stock options trader... I know i can execute futures from the depth of market, and i can execute stock orders from the depth of market as well, but for stock options is there a good way to execute these trades or should i just use my Interactive Brokers TWS platform? I would like to execute everything from the sierra charts platform though, i just don't know how to do options... |
[2016-10-31 17:23:28] |
To customize the menus that appear on a chart when right clicking with the Pointer, refer to this page: http://www.sierrachart.com/index.php?page=doc/GlobalSettingsMenu.html The only way to do what you want is to have one single Chartbook. Refer to: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html You can trade options through a chart or Trade DOM. That will work as well. But really because of the complexity of Interactive Brokers options symbols probably best you just trade them through TWS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
