Date/Time: Sat, 11 Jan 2025 02:14:05 +0000
chart DOM bid/ask histogram coloring
View Count: 1446
[2016-10-30 12:03:13]
ticinotrader - Posts: 397
Hi, I am using SC on two computers. I try to use the same settings for a Chart DOM on both computers so I copied the chartbook containing the chart with DOM to the another computer. It shows nearly identical DOM but on the second computer there is no histogram shown for the BID/ASK ladder. Please see this difference on the charts below.
http://www.sierrachart.com/image.php?Image=1477828231696.png
http://www.sierrachart.com/image.php?Image=1477828281913.png
I tried to find the settings what controls this (histogram coloring for Bid/ask ladder) but wasn't able to locate it. Can you please give me some hints where to find this setting?
Thank you.
[2016-10-31 08:26:35]
Refer to:
Global Trade Settings Windows: Chart DOM Settings
We think what you are referring to is the Display Volume Bar for Bid/Ask Sizes option.
