Date/Time: Sat, 11 Jan 2025 02:14:44 +0000
range bar?
View Count: 742
[2016-10-29 21:42:10]
zippyzip - Posts: 293
i was just messing around with diff type of range bars looking at 100 range on crude and they all plot the same and some are 20 ticks , some 50 ticks , some 80 ticks , shouldn't they be 100 ticks per bar ? thanks
[2016-10-29 21:48:33]
This is explained here:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
[2016-10-31 00:41:46]
ok i have my system set to those requirements already and i dont see any change in bar ?
[2016-10-31 01:14:25]
Do you have Chart >> Chart Settings >>New Bar at Session Start disabled?
