Date/Time: Sat, 11 Jan 2025 02:09:57 +0000
printing chart statistics
View Count: 894
[2016-10-29 10:37:28] |
canyiah - Posts: 48 |
I want to do statistics on the markets I trade like how many times the IB high is broken, how often a low volume that moves a market up holds, etc. Im assuming I have to use ACSIL but I dont see a function that prints to a file. How would I create statistics that i can look at in a file. I see the print to log function but not print to file.
[2016-10-29 22:45:42] |
You can use these C++ functions to read and write files: http://www.cplusplus.com/reference/cstdio/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
