Date/Time: Sat, 11 Jan 2025 03:36:01 +0000
Volume Profile on Trade DOM
View Count: 1463
[2016-10-29 03:53:06] |
tradernikki - Posts: 41 |
Can I put the volume profile on the right side of the DOM ONLY for the ZN While keeping the volume profile for ZB and ZF on the left side? Everytime I change the DOM column for one DOM, it updates in every other DOM. Thank you http://www.sierrachart.com/image.php?Image=147771326888.png Date Time Of Last Edit: 2016-10-29 03:54:46
[2016-10-31 09:32:08] |
Yes you can use this Volume by Price study Input: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_RightAlignVolumeBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
