Date/Time: Sat, 11 Jan 2025 02:15:49 +0000
3 requests
View Count: 818
[2016-10-28 22:49:09] |
User976133 - Posts: 38 |
Today while searching, I found 2 articles that I can not find with any search I try, and Chrome is losing my browsing history. 1) an article with rgb values and resulting colors. It must have had 20 - 30 rgb values. 2) an article with the source code cpp for the user defined studies 3) Not an article I have found, but some guidance. I want to refer to a different chart in code. Is that subgraph.sc(2) or [3] or whatever? Thank you |
[2016-10-29 08:20:06] |
1. Perform a general Internet search for this information. You should find plenty of webpages about this. Here is one website: http://htmlcolorcodes.com/ 2. Refer to this page: User Contributed Advanced Custom Study System Source Code 3. Refer to: Referencing Other Time Frames and Symbols When Using the ACSIL Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-29 08:21:23
