Date/Time: Sat, 11 Jan 2025 01:59:47 +0000
$INX data not real-time
View Count: 661
[2016-10-27 20:20:42] |
User484986 - Posts: 4 |
Hello, I do not have real time data on $INX for some reason. Everything else I seem to be able to get. What needs to be done to fix this? UPDATE: I'll reword this...I need the real-time S&P Index symbol for intraday chart. Thank you. Date Time Of Last Edit: 2016-10-27 21:50:14
[2016-10-27 21:52:10] |
This requires that you activate the S&P Indices exchange for 3.25 USD. You can do this here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
