Date/Time: Sat, 11 Jan 2025 02:15:51 +0000
New demo user
View Count: 523
[2016-10-27 16:54:02]
User100505 - Posts: 1
New CQG Web API demo user rebecca_prudhomme needs their 14 day trial enabled for CQG Web API.
Best regards,
Justin
[2016-10-27 17:12:03]
Your account has been activated and/or reset.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
Also there were some critical improvements made with handling orders from the CQG system when using the CQG web API. They need to run the latest prerelease for that. Here are the instructions to update:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
This is going to become the main release later today.
