Date/Time: Sat, 11 Jan 2025 02:08:15 +0000
need only todays values not multiple days
View Count: 648
[2016-10-27 16:38:21] |
User524378 - Posts: 7 |
Hi I am new to Sierra and I am having some difficulty with this program I, in principle, am trying to add just the High and Low of the current day to another program The way i started was to create an HiLo.cpp using samples and got this far. see attached i dont want multiple days just todays values I appreciate the help Thank you in advance |
HiLo.cpp - Attached On 2016-10-27 16:38:05 UTC - Size: 3.75 KB - 336 views |
[2016-10-27 16:43:38] |
We do not provide programming help. If you want to export study data, refer to: http://www.sierrachart.com/index.php?page=doc/EditMenu.html#ExportBarStudyDataToTextFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-27 18:00:17] |
where do i post for minor programming support
[2016-10-27 19:00:26] |
This is perfectly fine to post here about this, but just letting you know, we ourselves do not provide help but maybe another user might.
