Date/Time: Sat, 11 Jan 2025 02:19:26 +0000
Wathlist
View Count: 806
[2016-10-26 16:23:28]
User153928 - Posts: 35
Hi, I'm building a watch list with the Dow Jones Stocks and I have 3 stocks Sierra will not recognize CSCO Cisco System Inc. INTC Intel Corp. MSFT Microsoft Corp. all the other stocks come up OK and if I open up a chart with those symbols it comes up but with the incorrect numbers it shows the right numbers on my IB account which is linked to Sierra, please help,
thanks Walter
[2016-10-26 17:04:36]
We do not understand the nature of the problem.
Provide an image of one of the charts and only one of the charts, by following these instructions:
https://www.sierrachart.com/index.php?l=doc/PostingInformation.php#Image
Do not post any more than one chart. And only use the method documented in the link above.
Date Time Of Last Edit: 2016-10-27 16:44:31
[2016-10-27 16:05:12]
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=9533
I attached a snipping copy I hope you can see it that is the best I could do
thanks I hope it works
imageCapture.PNG / V - Attached On 2016-10-27 15:59:36 UTC - Size: 65.76 KB - 302 views
[2016-10-27 16:49:02]
For those symbols you need to use the Interactive Brokers symbol format which also specifies the Primary Exchange:
http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock
[2016-10-27 19:47:33]
Thank you so much
Walter
