Date/Time: Sat, 11 Jan 2025 02:19:58 +0000
Equity Curve
View Count: 2131
[2016-10-26 13:57:26] |
User297539 - Posts: 55 |
Hallo SC, Es wäre Gut, wenn ein Trader seinen gemachten Trades grafisch Ansehen könnte. Eine Equity Curve im bereich Trade Activity Log, wäre sehr Hilfreich. |
Equity.jpg / V - Attached On 2016-10-26 13:56:35 UTC - Size: 100.48 KB - 528 views |
[2016-10-26 17:09:34] |
This is not supported but for the particular trading data studies that are available, refer to: http://www.sierrachart.com/index.php?page=doc/TradeStatusWindows.html#TradeDataStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
