Date/Time: Sat, 11 Jan 2025 02:20:19 +0000
Amp futures and Sierra Charts connection
View Count: 2120
[2016-10-26 09:43:05] |
User528725 - Posts: 2 |
Hi I am pretty confused by what appears to be conflicting messages about using AMP futures data with Sierra Charts. ~On your 'external supported devices' page as per the attached there is no mention of Amp futures? ~On Amp home page it says your charts are free with Amp futures? (see attached) ........or are you talking about different services? Also as per the instructions on SC page re linking to data services: ~in global settings/data trade feed services SELECT 'AMP/TTNET' and the config box which comes up is different to the one on your instructions page. There are no tabs for starters - is this because its demo version, and no 'sender comp id' etc. I would attach the files but it appears I have reached my limit - I will respond to this message and attach the 2 files 'SC Amp feed instr' and 'SC Amp feed'. So with the above in mind, how the hell do I connect my Amp futures account to Sierra Charts? Or am I better off doing this from Amp Futures end? (I am currently waiting for my funds to credit the Amp account). Regards, Russell |
SC external services.png / V - Attached On 2016-10-26 09:29:00 UTC - Size: 19.97 KB - 371 views Amp home page SC offer.png / V - Attached On 2016-10-26 09:33:27 UTC - Size: 34.85 KB - 357 views |
[2016-10-26 09:57:49] |
...these are the 2 other files 'SC Amp feed instr' and 'SC Amp feed'. I have also uploaded the documentation link image which just links to an error 404 page. So is there documentation documents we can download? rgds, Russell |
SC Amp feed instr.png / V - Attached On 2016-10-26 09:56:00 UTC - Size: 49.79 KB - 414 views SC Amp feed.png / V - Attached On 2016-10-26 09:56:09 UTC - Size: 31.67 KB - 412 views SC error.png / V - Attached On 2016-10-26 09:56:19 UTC - Size: 6.12 KB - 317 views |
[2016-10-26 10:08:12] |
You really need to rely on your broker for answers to your questions. The Data/Trade Service Settings image for TT FIX does need to be updated and we will do that.
