Date/Time: Sat, 11 Jan 2025 04:35:22 +0000
S5 DOM sync with Sierra
View Count: 1797
[2016-10-26 09:33:00]
User252419 - Posts: 235
I want to see the orders I place in S5 DOM in Sierra. How can I do it?
Thank you
[2016-10-26 17:16:41]
Make sure Sierra Chart is not in Trade Simulation Mode:
http://www.sierrachart.com/index.php?page=doc/Trading.html#DifferenceBetweenSimAndNonSim
Also refer to:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ViewingOrdersOnTheChart
[2016-10-26 17:19:34]
Can't I see the orders in Sim Mode if I'm in Sim DOM?
[2016-10-26 17:38:45]
Is Trade >> Trade Simulation Mode On enabled? It should not be.
[2016-10-27 07:38:05]
Is deactivated. However, I don't place orders with SierraChart DOM. I place orders with S5 DOM. So I'm wondering if it is possible to sync orders to SierraChart.
Thank you,
[2016-10-27 07:56:36]
Do you see the orders listed on the Trade >> Trade Orders and Positions >> Orders tab?
Date Time Of Last Edit: 2016-10-27 07:56:55
[2016-10-27 08:00:58]
I'm placing orders in S5 Trade Demo and I don't see any order in Trade >> Trade Orders and Positions >> Orders tab
[2016-10-27 08:55:50]
What is Global Settings >> Data/Trade Service Settings >>Service Setting >> Server set to? It should be the Simulation server.
[2016-10-27 09:00:53]
I changed it now to sim.gainfutures.com but still not working
[2016-10-27 09:45:19]
Make sure your reconnect to the data feed following these instructions after changing that setting:
[2016-10-27 12:06:12]
It seems I can not connected to the sim.gainfutures.com. I can only connect to prod.gainfutures.com
This is the log message:
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2016-10-27 14:03:22
GainCapital FIX Trading socket (0) | Resolved address sim.gainfutures.com to IP 64.94.37.207. | 2016-10-27 14:03:22
GainCapital FIX Trading socket (79) | Connected. | 2016-10-27 14:03:22
GainCapital FIX Trading: Sending the Logon message. | 2016-10-27 14:03:22
GainCapital FIX Trading | Connected to trading server. | 2016-10-27 14:03:23
GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2016-10-27 14:03:23
GainCapital FAST Data socket (0) | Resolved address sim.gainfutures.com to IP 64.94.37.207. | 2016-10-27 14:03:23
GainCapital FIX Trading: Received a Logout message. Text = User temporarily locked out | 2016-10-27 14:03:23
GainCapital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2016-10-27 14:03:23
GainCapital FIX Trading socket (79) | Shutdown and closed. | 2016-10-27 14:03:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-27 14:03:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-27 14:03:23
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-27 14:03:23
GainCapital FAST Data socket (80) | Shutdown and closed. | 2016-10-27 14:03:23
GainCapital FAST Data: Socket connection was closed without any logout messages sent or received. | 2016-10-27 14:03:23
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-10-27 14:03:23
GAIN Capital/OEC | Disconnected. | 2016-10-27 14:03:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-27 14:03:23
[2016-10-27 17:19:40]
You will need to ask your broker Gain Capital to help you with the connection problem to the simulation server.
Here is the relevant documentation:
http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem
[2016-11-03 10:44:00]
I'm finally connected to the Sim server and I see the orders in Trade >> Trade Orders and Positions >> Orders tab. But I don't see them plotted in the chart.
The configuration I have is this:
-Show order fills
-Show Orders and positions
Thank you,
[2016-11-03 17:17:01]
Make sure Trade >> Trade Simulation Mode On is disabled. Here are detailed instructions:
[2016-11-03 18:32:38]
Trade Simulation Mode On is disabled but still not working.
[2016-11-03 18:45:48]
Do you have the proper Account number specified in the Account field in Global Settings >> Data/Trade Service Settings?
Date Time Of Last Edit: 2016-11-04 06:14:46
[2016-11-07 09:58:07]
Yes I have. And I can see the orders in Trade >> Trade Orders and Positions >> Orders tab but not in the charts. Thank you
[2016-11-07 18:53:26]
What is the symbol of the order and what is the symbol of the chart?
There must be a mismatch there.
[2016-11-07 19:05:21]
ESZ6 and ESZ6, they match
[2016-11-07 19:28:20]
Does the Trade Account of the order match the Trade Account set on the Trade Window for the chart:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SelectingTradeAccount
[2016-11-07 19:43:56]
In Orders and Positions window I see DEMO061719 in Trade account tab. And in Trade window I can only see E76103 (my live account) or Sim1 if I choose Trade Simulation Mode ON. I can not select DEMO06119
[2016-11-07 20:04:52]
You need to add that other account to File >> Data/Trade Service Settings in the Account field. Add it. You can have multiple accounts separated by a comma.
