Date/Time: Sat, 11 Jan 2025 01:57:15 +0000
RE: Can't delete rectangle box on chart
View Count: 949
[2016-10-26 04:39:14] |
User794782 - Posts: 9 |
I have the correct chart and can not delete rectangle box, I've double checked all my other charts to see if it was installed on another chart. Please advise, thank you. |
[2016-10-26 05:08:00] |
Do you see it listed in Tools >> Manage Chart Drawings Window?
[2016-10-26 13:20:44] |
Yes, thank you Resolved |
