Date/Time: Sat, 11 Jan 2025 01:55:32 +0000
Unable to plot 20 days of 30 min IntradayChart
View Count: 692
[2016-10-25 19:51:42] |
User252419 - Posts: 235 |
Hello, I can not plot a 30min chart or any intraday chart with more than 1 day of data. I can not see any previous day in intraday cahrts unless it is a historical data chart. These are my configurations: *Chart Settings: -20 days to load. -Load All Weekend Data -Start Time: 00:00:00 -End Time: 23:59:59 *Date/Trade Service Settings: Intraday Data Storage Time Unit: 1 tick (my data provider has it) -Number of Stored Time and Sales Records: 4700 -Non-Tick Data: 186 -1-Tick Data: 186 *Intraday Data Editor - ESZ16.scid -Date: 2016-10-25 -Time:21:00:00.000 What should I do? Thank you, |
[2016-10-25 20:36:27] |
The symbol of the chart is not correct. It needs to be ESZ6. Follow the instructions here to change it: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-25 20:36:38
[2016-10-25 20:42:06] |
I wrote it wrong in the previous message, I have symbol right.
[2016-10-25 20:43:41] |
So with symbol right is not working. What should I do? Thank you, |
[2016-10-25 20:50:59] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-25 21:07:02] |
http://www.sierrachart.com/image.php?Image=1477429742212.png
Date Time Of Last Edit: 2016-10-25 21:09:18
[2016-10-25 21:15:34] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings When that is done, re-download the data in the chart with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
