Date/Time: Sat, 11 Jan 2025 02:13:08 +0000
If Intraday Chart Bar Period is switched from Time to Range, Chart Reloads Continuously
View Count: 606
[2016-10-25 17:48:11] |
TapeReader - Posts: 89 |
Hi, If I switch an intraday chart's 'Bar Period Type' from 'Days-Mins-Secs Per Bar' to 'Range Per Bar-Standard (in ticks) and apply a custom study, the chart goes into a continual reload mode (see log files). This behavior is new, and started with a recent upgrade of Sierra Chart somewhere around builds 1471-1475. This behavior was replicated on 3 separate machines. On 2 of the machines, removing the instrument's .scid file and downloading a new file remediated the issue. On the 3rd machine, removing the instrument's .scid file and downloading a new file did not fix the issue. If the custom study is removed, then the reloading stops. If the chart is reverted to 'Days-Mins-Secs Per Bar' the reloading stops. Any insights here? |
Continually Reloading Chart Issue.txt - Attached On 2016-10-25 17:46:57 UTC - Size: 5.4 KB - 362 views |
[2016-10-25 18:13:44] |
This problem has been solved in the latest prerelease. Update with Help >> Download Prerelease. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-25 18:43:56] |
Thanks for this...I can affirm that the new build has remediated the issue. As always, you guys are amazing. |
