Date/Time: Sat, 11 Jan 2025 01:56:30 +0000
How to attach Chart to window
View Count: 884
[2016-10-25 06:56:03]
User33743 - Posts: 83
I'd like to ask you how to attach chart window like this (1)or (2)when its active(By active i mean when i'm working on it). Screen 2 is always when chart is "not active" but when i click on it becoming like screen (12)
Chart is always switching from (2) to (12)when i click on it what is a little bit annoying.
Could you help me with this?
Best Regards
image1.jpg / V - Attached On 2016-10-25 06:47:29 UTC - Size: 94.2 KB - 302 views
image2.jpg / V - Attached On 2016-10-25 06:52:17 UTC - Size: 86.19 KB - 259 views
image12.jpg / V - Attached On 2016-10-25 06:52:22 UTC - Size: 90.42 KB - 303 views
[2016-10-25 10:45:34]
Disable this option:
General Settings Window: Auto Hide Charts Title Bar And Scrollbar (Global Settings >> General Settings >> GUI >> Application GUI)
To attach a window back to the main Sierra Chart window, refer to:
Detaching and Attaching Chart Windows
[2016-10-25 11:16:39]
This is exactly what i was looking for!
Thank you very much.
One more question, hope you can help me in this post:
Is there any option which save position of charts on other displays after restarting the platform?
I see that sometimes chartbooks open without attacching chart to the displays like it was last time, so i need manualy set chart on proper screen.
Best Regards
[2016-10-25 17:01:30]
This is a Windows operating system problem. Refer to:
http://www.sierrachart.com/index.php?page=doc/helpdetails14.html
[2016-10-26 09:56:42]
Thank you very much!
[2016-10-26 10:04:23]
There is no need to say thank you. This is unwelcome.
