Date/Time: Sat, 11 Jan 2025 02:02:46 +0000
[User Discussion] - Histogram or "block" study for Zig Zag "Time Duration"
View Count: 2209
[2016-10-25 04:08:55]
User68474 - Posts: 201
With the "Zig-Zag" Settings, it is possible, of course, to display a variety of text displays/labels(e.g. HH,HL,LL,LH Labels; Reversal Price; Length of Zig-Zag Line; Zig-Zag Volume; Time Duration, etc.) In the case of the Zig-Zag Volume, one can further add the "Zig-Zag Cumulative Volume" study in another Chart Region below the Main Region in a useful histogram display to correspond with the "swings". It would be most useful and informative to also see "Time Duration" below, perhaps in a similar "cumulative" display, or perhaps a simple "block" format. Is this possible? Has anyone else ever requested this or maybe created a custom study that is available in Study archives?
[2016-10-25 04:19:47]
You can certainly modify the study to meet your requirements:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
Otherwise, this is not something we would get involved with.
[2016-10-25 06:31:32]
Sawtooth - Posts: 4147
You can do this with the Spreadsheet Study study.
Attached is an example chartbook and spreadsheet file that creates an histogram, and a screen capture of what it looks like.
In cell H2, the user can select the display units in seconds, minutes or hours.
imageZZ Time Duration.PNG / V - Attached On 2016-10-25 06:26:26 UTC - Size: 83.75 KB - 743 views
attachmentZZ Time Duration.cht - Attached On 2016-10-25 06:27:02 UTC - Size: 38.96 KB - 497 views
attachmentZZ Time Duration.scss - Attached On 2016-10-25 06:27:21 UTC - Size: 58 KB - 362 views
[2016-10-25 21:30:05]
Thanks, "tomglib". I recall you helped me out with another topic in the past. I much appreciate your input/advice once again.
Embarrassingly, I don't really know how to take your ".cht" and ".scss" and do anymore with them but to copy and paste to my SC "Data Folder" in "C" Drive. I can open it up as a Chartbook and Spreadsheet, but , unfortunately I am quite lame when it comes to softwear type "gymnastics". I typed/copied what you highlighted in blue on the .scss .PNG into Column H [BTW, it says 8 views, but I only see the one chart and spreadsheet image when I click on/open the .PNG. (More embarrassment!)], but, of course, no histogram appeared to populate Region 2 below the chart. I realize there is more to do than that, but I'm admittedly simply ignorant of what to do! Thanks again from a REAL old timer.
[2016-10-26 00:10:39]
To use the ZZ Time Duration spreadsheet study on an existing chart:
-Put the ZZ Time Duration.scss from post#3 in your Sierra Chart \Data folder.
-Put the attached study collection file ZZ Time Duration-.StdyCollct in your Sierra Chart \Data folder.
-Focus your chart and go to Analysis >> ZZ Time Duration- and choose No when asked if you want to 'Clear Existing Studies On Chart'.
-Go to your existing Zigzag study settings and set 'Additional Outputs For Spreadsheets' to Yes.
-Note the ID# of your existing Zigzag study.
-On the spreadsheet: Edit the formula in cell K3 to reference the ID# of your existing Zigzag study. (If it's not ID1).
attachmentZZ Time Duration-.StdyCollct - Attached On 2016-10-26 00:07:16 UTC - Size: 9.4 KB - 445 views
[2016-10-26 04:54:05]
Thanks, tomglib. Not able to see anything displayed yet. Can I infer from your statement: "-On the spreadsheet: Edit the formula in cell K3 to reference the ID# of your existing Zigzag study. (If it's not ID1).", that I should at least see cell K3 filled with "ID:1" on the .scss (if my existing Zigzag study is ID:1) ? It (cell K3) is perfectly blank on the spreadsheet.
[2016-10-26 05:22:52]
On the spreadsheet, go to the upper left corner and use the dropdown to select Sheet1.
Then go to cell K3.
What is the ID# of your Zigzag study?
[2016-10-26 05:38:36]
It is already on Sheet 1, and even if I drop down, there are no other choices but Sheet 1. On the chart I'm working with now (which is your "ZZ Time Duration .cht) it is, in fact, ID:1.
[2016-10-26 05:47:36]
The study name and input values, settings, etc. ARE visible in Region 2, but no scale on right and, of course, no bars/histogram.
[2016-10-26 13:11:41]
Please contact via email:
tom@sawtoothtrade.com
