Date/Time: Sat, 11 Jan 2025 01:47:46 +0000
VisualCCompile.Bat
View Count: 733
[2016-10-24 22:27:55]
doubletop11 - Posts: 5
What does this mean when I try to compile something in SierraCharts?
C:\Windows\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat"
C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
'cl' is not recognized as an internal or external command,
operable program or batch file.
-- End of Build -- 17:23:11
I've installed the compiler already from MS. Did something go wrong in the install???
[2016-10-24 22:47:50]
Apparently the installation of the Visual C++ compiler is not correct for some reason.
Just give us about another day and we will have remote build functionality available which will work around this.
[2016-10-27 20:33:22]
I updated to version 1478 and tried to build it again today. I got the same message. Any updates on when this should be resolved?
[2016-10-27 21:52:40]
Use the "Remote Build" command on the Build Custom Studies DLL window. This now works in version 1478.
Date Time Of Last Edit: 2016-10-27 21:53:20
