Date/Time: Sat, 11 Jan 2025 02:04:37 +0000
Do you have this specific indicator ?????
View Count: 671
[2016-10-24 21:09:01]
User54459 - Posts: 7
Very simply I was just looking for a indicator(I used to have with Ninja charts)
I just want to be able to see the size of the last candlestick without measuring with a crosshair. Example is last candle was 10Pts I would be able to see that.
Thank You
[2016-10-24 22:30:52]
This can be done. Use the Bar Difference study:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s56
You can also display the values as text using the Value of Subgraph Draw Style:
Chart Studies: Subgraphs Tab >> Draw Style
