Date/Time: Sat, 11 Jan 2025 02:11:09 +0000
AMP/TTnet Connection keep dropping
View Count: 1061
[2016-10-24 07:47:02]
User529859 - Posts: 18
is there anyway to improve connection ?
thanks
Rex
[2016-10-24 09:13:08]
There is nothing that we can do to help with this.
Have your broker change your account to use CQG.
You could also consider using the new CTS connection:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
[2016-10-24 12:48:22]
Does AMP support CTS? how to get demo account for this connection?
thanks
Rex
[2016-10-24 17:35:24]
AMP does not support CTS. You will need to use another broker. It will be a broker who uses Wedbush or Dorman for clearing.
We have assigned your Sierra Chart account a CTS demo account. This is now done.
Follow through the instructions starting at step 12 here:
Also make sure you are running the latest version of Sierra Chart.
Date Time Of Last Edit: 2016-10-24 17:38:34
[2016-10-25 07:06:18]
follow the steps, but no realtime data stream in. I have Sierra Datafeed on my account.
thanks
Rex
[2016-10-25 09:34:17]
Make sure the charts are set to the correct symbols. They are found under File >> Find Symbol.
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-10-25 12:42:16]
thanks, it works, symbol issue.
Rex.
[2016-10-26 04:12:08]
Let us know how the new CTS connection is working for you.
