Date/Time: Sat, 11 Jan 2025 02:20:40 +0000
IB connection to SC
View Count: 905
[2016-10-22 20:54:34] |
brando - Posts: 14 |
Have newly installed Windows 10 on laptop and cannot connect to SC. Received error message to install 32-bit TWS over 64-bit and get API software from IB. Did this and still cannot connect. Prior to installing Win10 connection worked ok. Sending error log. Cancel request--found a settings error.
Date Time Of Last Edit: 2016-10-22 21:31:34
[2016-10-22 21:11:46] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
