Date/Time: Sat, 11 Jan 2025 02:06:31 +0000
Sub Instances & Global P/L Management
View Count: 746
[2016-10-22 10:06:32] |
Marmany - Posts: 307 |
I have a 1st Instance remaining on a Live Account and Sub Instances which toggle between Sim and Live. Trade Activity Log on 1st Instance always correctly reports live trades from all the Sub Instances. However Global Profit/Loss Management on 1st Instance only picks up correct position for Live Trades if an intraday chart for the symbol traded via a Sub Instance is open on the 1st Instance. I can not find reference to this requirement and my interpretation of the Sierra Manual is that Global P/L Management picks up data from the same source as the Trade Activity Log (which does not require open charts on 1st Instance). There is not a problem as charts can be minimised and I have plenty of spare CPU and memory available. Maybe I have an incorrect setting somewhere that makes the charts necessary on 1st Instance? Please advise. |
[2016-10-22 23:37:54] |
This is actually correct and is documented here: Global Profit/Loss Management: Functional Description Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
