Date/Time: Sat, 11 Jan 2025 01:10:27 +0000
Adjust Bar Periods for all charts
View Count: 795
[2016-10-20 01:50:16] |
sellis67 - Posts: 105 |
is there a way to change all 9 of my charts to the same bar period at the same time?
[2016-10-20 02:50:21] |
You need to use the Chart Linking feature for this: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
