Date/Time: Sat, 11 Jan 2025 00:55:31 +0000
copying a formula related chart to another chartbook
View Count: 655
[2016-10-19 20:11:54] |
User326163 - Posts: 18 |
Hello, I am brand new to Sierra. I would like to move a formula-related chart over to another chartbook. What is the best way to do so? I got a lot of help to create this chart from a Sierra Engineer so to redo the chart would be very difficult for a beginner like me. Would appreciate any advice. Thanks in advance. |
[2016-10-19 20:52:26] |
You need to use this command: Chart Menu: Duplicate Chart To Chartbook (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
