Date/Time: Sat, 11 Jan 2025 00:54:53 +0000
tradedom text font and grid problem
View Count: 634
[2016-10-19 19:47:40] |
User497523 - Posts: 4 |
Attempting to increase the text font size in tradedom to 12, the default font is tiny. tradedom screen at 12 font now missing price levels and horiz grid overlaps text. Any suggestions? Thanks
[2016-10-19 20:09:13] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-19 20:22:04] |
http://www.sierrachart.com/image.php?Image=1476908322271.png
[2016-10-19 20:51:58] |
This looks good. We do not think you can make it any better than this. Although refer to: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-19 21:05:42] |
grid lines are running through the levels. your dom is poorly put together
[2016-10-19 21:31:26] |
You are misunderstanding how it works and the capabilities. We now understand what you are saying more clearly. Originally we thought you meant the text was overlapping and we had not seen that. And we thought that some of the depth quantities were missing but we did not see that either. Once again refer to this page: The Chart DOM Scale That explains how to scale the Chart/Trade DOM and resetting it with Auto Scale the Chart DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-19 21:32:59
[2016-10-19 22:01:31] |
got it. thanks for your help.
