Date/Time: Sat, 11 Jan 2025 00:38:25 +0000
Server Side OCO Failure, and Incorrect Position/Missing Fill Data after Connection Reset
View Count: 1594
[2016-10-19 18:55:47] |
User948528 - Posts: 108 |
v1473, pkg 3, Rithmic, through Amp, server side OCO enabled. While in a position, lost internet, one side of OCO hit, position closed while disconnected. Multiple problems resulted: 1. Without connection, server side OCO failed to function, unfilled side of OCO remained working at exchange. Was lucky to be able to cancel it manually in this case after connection restored. 2. SC never received the order fill that occurred while disconnected, even after connection restored, disconnect/reconnect to trade service, refresh trade data function, and even restarting SC, position still remains open in SC, while broker confirms flat. 3. Global PnL Management as documented will malfunction in this case. Any way to prevent this? Will it even accidentally enter a new position while trying to flatten a non-existent incorrect position? |
[2016-10-19 20:54:12] |
1. If you are certain the OCO order was on the server side, then contact your broker about this. The Trade Activity Log will indicate if it was a server-side OCO: Trade Activity Log So you need to find out if the Rithmic server did not handle the OCO properly. 2. OK. There is no guarantee this will happen. 3. It is not going to flatten a nonexistent Trade Position because the Position should no longer exist in Trade >> Trade Orders and Positions >> Positions and the determination of what Positions exist is always from that tab. Although it will take about five seconds for that tab to update upon a connection and there is the possibility a flatten command could be automatically sent before then. You might be interested in this new service we are offering: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-19 20:54:52
[2016-10-19 22:20:15] |
1. Where exactly in the Activity Log will a server-side OCO be indicated? If Use Server-Side OCO and Bracket Orders is checked, why would it not be used, with Rithmic through Amp?
[2016-10-19 22:44:32] |
1. This is indicated in the Order Action Source text with the order. It will say something like "server-side OCO". As long as the option is enabled, it should be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-20 16:41:20] |
Use Server Side OCO is enabled but Server-side OCO is not indicated under Order Action Source in the Trade Activity tab.
Date Time Of Last Edit: 2016-10-20 16:41:46
[2016-10-20 17:04:09] |
Checking on this. Also, there is a notice given on the Order Confirmation whether server-side OCO is being used. So that is something you need to pay attention to. Refer to: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#OCOManagementServersideOnly Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-20 17:09:12] |
The notice on the order confirmation says this service does not support OCO orders.
Date Time Of Last Edit: 2016-10-20 17:11:28
[2016-10-20 17:16:12] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-21 02:41:11] |
Reading Internal Order ID file. | 2016-10-20 22:38:01 Reading Trade Orders file. | 2016-10-20 22:38:01 Reading Trade Positions file. | 2016-10-20 22:38:01 Software version: 1473 | 2016-10-20 22:38:01 Uses New Spreadsheets | 2016-10-20 22:38:01 Enabled for: Advanced Features. | 2016-10-20 22:38:01 Enabled for: Sierra Chart Historical Data Service. | 2016-10-20 22:38:01 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-10-20 22:38:01 Current selected Data/Trading service: Rithmic Trading | 2016-10-20 22:38:01 Chart Update Interval: 900 | 2016-10-20 22:38:01 Data/Trade Service Settings automatically set. | 2016-10-20 22:38:01 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-10-20 22:38:01 2016-10-20 22:38:07 Local computer time | 2016-10-20 22:38:01 2016-10-21 02:38:07 Local computer time in UTC | 2016-10-20 22:38:01 2016-10-20 22:38:07 Local computer time in SC Time Zone | 2016-10-20 22:38:01 2016-10-21 02:38:03 Server time in UTC | 2016-10-20 22:38:01 Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-10-20 22:38:01 Program path: C:\SierraChart\MAIN-Rithmic\ | 2016-10-20 22:38:01 Data Files path: C:\SierraChart\MAIN-Rithmic\Data\ | 2016-10-20 22:38:01 OS Version Number: 6.2 | 2016-10-20 22:38:01 Locale Setting: C | 2016-10-20 22:38:01 Created the DTC Protocol server. | 2016-10-20 22:38:01 DTC Protocol Server listening on port 11099. | 2016-10-20 22:38:01 Created the DTC Protocol historical data server. | 2016-10-20 22:38:01 HD Server Manager | Listening on port 11098 | 2016-10-20 22:38:01 Checking for new symbol settings for rim | 2016-10-20 22:38:01 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-20 22:38:01 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-10-20 22:38:01 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-10-20 22:38:01 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-10-20 22:38:01 Symbol settings are up-to-date for rim | 2016-10-20 22:38:08 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-20 22:38:10 HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-10-20 22:38:10 Files to Open on Start up | Opening file: Daily.cht | 2016-10-20 22:38:11 GCZ6-COMEX [CBV] Daily #2 | Reloading chart. | 2016-10-20 22:38:11 NQZ6-CME [CBV] Daily #10 | Reloading chart. | 2016-10-20 22:38:11 CLZ6-NYMEX Daily #4 | Reloading chart. | 2016-10-20 22:38:11 ZSX6-CBOT [CBV] Daily #3 | Reloading chart. | 2016-10-20 22:38:11 6BZ6-CME [CBV] Daily #7 | Reloading chart. | 2016-10-20 22:38:11 NGX6-NYMEX [CBV] Daily #1 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Primary.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:11 NGX6-NYMEX [CBV] 60 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:11 GCZ6-COMEX [CBV] 30 Min #1 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:11 NQZ6-CME [CBV] 30 Min #4 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:11 CLZ6-NYMEX [CBV] 30 Min #6 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for ZSX6-CBOT | 2016-10-20 22:38:11 ZSX6-CBOT [CBV] 30 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:11 6BZ6-CME [CBV] 30 Min #5 | Reloading chart. | 2016-10-20 22:38:11 6BZ6-CME [CBV] 30 Min #5 | Error while getting daily open price with date 2016-09-22 from file. C:\SierraChart\MAIN-Rithmic\Data\B6Z16.dly. Error: Date not found | 2016-10-20 22:38:11 GCZ6-COMEX [CBV] Daily #7 | Reloading chart. | 2016-10-20 22:38:11 CLZ6-NYMEX [CBV] Daily #8 | Reloading chart. | 2016-10-20 22:38:11 NQZ6-CME [CBV] Daily #9 | Reloading chart. | 2016-10-20 22:38:11 6BZ6-CME [CBV] Daily #10 | Reloading chart. | 2016-10-20 22:38:11 ZSX6-CBOT [CBV] Daily #11 | Reloading chart. | 2016-10-20 22:38:11 NGX6-NYMEX [CBV] Daily #12 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Crude.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:11 CLZ6-NYMEX 5 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:11 CLZ6-NYMEX 1 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:11 CLZ6-NYMEX [CBV] 15 Min #4 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:11 CLZ6-NYMEX 1000 Volume #6 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Gold.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:11 GCZ6-COMEX 300 Volume #1 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:11 GCZ6-COMEX 5 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:11 GCZ6-COMEX 1 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:11 GCZ6-COMEX [CBV] 15 Min #4 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Nasdaq.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:11 NQZ6-CME 300 Volume #1 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:11 NQZ6-CME 5 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:11 NQZ6-CME [CV] 15 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:11 NQZ6-CME 1 Min #4 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Pound.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:11 6BZ6-CME 144 Volume #1 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:11 6BZ6-CME 5 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:11 6BZ6-CME [CV] 15 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:11 6BZ6-CME 1 Min #4 | Reloading chart. | 2016-10-20 22:38:11 Files to Open on Start up | Opening file: Nat Gas.cht | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:11 NGX6-NYMEX 300 Volume #1 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:11 NGX6-NYMEX 1 Min #3 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:11 NGX6-NYMEX 5 Min #2 | Reloading chart. | 2016-10-20 22:38:11 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:11 NGX6-NYMEX 15 Min #4 | Reloading chart. | 2016-10-20 22:38:11 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-10-20 22:38:11 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-10-20 22:38:11 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-10-20 22:38:11 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-10-20 22:38:11 Chart #10 has tagged chart #5 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 Chart #10 has tagged chart #5 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 Chart #11 has tagged chart #3 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 Chart #11 has tagged chart #3 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 Chart #12 has tagged chart #2 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 Chart #12 has tagged chart #2 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:11 HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-10-20 22:38:11 HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-10-20 22:38:11 HD Request # 2 | Downloading Historical Daily chart data for GCZ6-COMEX. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 2 | Requesting historical Daily data for GCZ16 starting at 2016-10-19 | 2016-10-20 22:38:19 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-10-20 22:38:19 HTTP connection to ds01.ddfplus.com:80 (5) | Connected. | 2016-10-20 22:38:19 NGX6-NYMEX [CBV] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:19 HD Request # 2 | Receiving historical Daily data for GCZ6-COMEX starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 2 | Writing historical Daily data to the file GCZ6-COMEX.dly | 2016-10-20 22:38:19 HD Request # 2 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for GCZ6-COMEX | 2016-10-20 22:38:19 HD Request # 2 | Daily download COMPLETE for GCZ6-COMEX. Completion time: 0s. Unique request ID: 1 | 2016-10-20 22:38:19 Removed historical data download ID 1 | 2016-10-20 22:38:19 HD Request # 3 | Downloading Historical Daily chart data for NQZ6-CME. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 3 | Requesting historical Daily data for NQZ16 starting at 2016-10-19 | 2016-10-20 22:38:19 ZSX6-CBOT [CBV] 30 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:19 6BZ6-CME [CBV] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:19 GCZ6-COMEX [CBV] Daily #7 | Reloading chart. | 2016-10-20 22:38:19 HD Request # 3 | Receiving historical Daily data for NQZ6-CME starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 3 | Writing historical Daily data to the file NQZ6-CME.dly | 2016-10-20 22:38:19 HD Request # 3 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for NQZ6-CME | 2016-10-20 22:38:19 HD Request # 3 | Daily download COMPLETE for NQZ6-CME. Completion time: 0s. Unique request ID: 2 | 2016-10-20 22:38:19 Removed historical data download ID 2 | 2016-10-20 22:38:19 HD Request # 4 | Downloading Historical Daily chart data for CLZ6-NYMEX. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 4 | Requesting historical Daily data for CLZ16 starting at 2016-10-19 | 2016-10-20 22:38:19 NQZ6-CME [CBV] Daily #9 | Reloading chart. | 2016-10-20 22:38:19 Chart #7 has tagged chart #1 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 Chart #7 has tagged chart #1 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 Chart #7 has tagged chart #1 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 Chart #9 has tagged chart #4 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 Chart #9 has tagged chart #4 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 Chart #9 has tagged chart #4 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:19 HD Request # 4 | Receiving historical Daily data for CLZ6-NYMEX starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 4 | Writing historical Daily data to the file CLZ6-NYMEX.dly | 2016-10-20 22:38:19 HD Request # 4 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for CLZ6-NYMEX | 2016-10-20 22:38:19 HD Request # 4 | Daily download COMPLETE for CLZ6-NYMEX. Completion time: 1s. Unique request ID: 3 | 2016-10-20 22:38:19 Removed historical data download ID 3 | 2016-10-20 22:38:19 HD Request # 5 | Downloading Historical Daily chart data for ZSX6-CBOT. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 5 | Requesting historical Daily data for ZSX16 starting at 2016-10-19 | 2016-10-20 22:38:19 HD Request # 5 | Receiving historical Daily data for ZSX6-CBOT starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 5 | Writing historical Daily data to the file ZSX6-CBOT.dly | 2016-10-20 22:38:19 HD Request # 5 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for ZSX6-CBOT | 2016-10-20 22:38:19 HD Request # 5 | Daily download COMPLETE for ZSX6-CBOT. Completion time: 0s. Unique request ID: 4 | 2016-10-20 22:38:19 Removed historical data download ID 4 | 2016-10-20 22:38:19 HD Request # 6 | Downloading Historical Daily chart data for 6BZ6-CME. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 6 | Requesting historical Daily data for B6Z16 starting at 2016-10-19 | 2016-10-20 22:38:19 HD Request # 6 | Receiving historical Daily data for 6BZ6-CME starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 6 | Writing historical Daily data to the file 6BZ6-CME.dly | 2016-10-20 22:38:19 HD Request # 6 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for 6BZ6-CME | 2016-10-20 22:38:19 HD Request # 6 | Daily download COMPLETE for 6BZ6-CME. Completion time: 0s. Unique request ID: 5 | 2016-10-20 22:38:19 Removed historical data download ID 5 | 2016-10-20 22:38:19 HD Request # 7 | Downloading Historical Daily chart data for NGX6-NYMEX. Starting date: 2016-10-20. Service: rim | 2016-10-20 22:38:19 HD Request # 7 | Requesting historical Daily data for NGX16 starting at 2016-10-19 | 2016-10-20 22:38:19 HD Request # 7 | Receiving historical Daily data for NGX6-NYMEX starting at 2016-10-20 | 2016-10-20 22:38:19 HD Request # 7 | Writing historical Daily data to the file NGX6-NYMEX.dly | 2016-10-20 22:38:19 HD Request # 7 | Received 3 records from 2016-10-20 00:00:00 to 2016-10-21 00:00:00 (2.0 days) and wrote 2 records for NGX6-NYMEX | 2016-10-20 22:38:19 HD Request # 7 | Daily download COMPLETE for NGX6-NYMEX. Completion time: 0s. Unique request ID: 6 | 2016-10-20 22:38:19 Removed historical data download ID 6 | 2016-10-20 22:38:19 6BZ6-CME [CBV] Daily #7 | Reloading chart. | 2016-10-20 22:38:20 NGX6-NYMEX [CBV] Daily #1 | Reloading chart. | 2016-10-20 22:38:20 Rithmic Trading | Port for executable: 63304 | 2016-10-20 22:38:20 Listening socket (1188), port 63304 | Closed. | 2016-10-20 22:38:20 Rithmic Trading | Starting server: C:\SierraChart\MAIN-Rithmic\Rim\DTCBridge.exe | 2016-10-20 22:38:20 GCZ6-COMEX [CBV] 30 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:20 NQZ6-CME [CBV] 30 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:20 GCZ6-COMEX [CBV] Daily #2 | Reloading chart. | 2016-10-20 22:38:20 NQZ6-CME [CBV] Daily #10 | Reloading chart. | 2016-10-20 22:38:20 6BZ6-CME [CBV] Daily #10 | Reloading chart. | 2016-10-20 22:38:20 CLZ6-NYMEX Daily #4 | Reloading chart. | 2016-10-20 22:38:20 ZSX6-CBOT [CBV] Daily #3 | Reloading chart. | 2016-10-20 22:38:20 Chart #10 has tagged chart #5 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #10 has tagged chart #5 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #10 has tagged chart #5 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 ZSX6-CBOT [CBV] Daily #11 | Reloading chart. | 2016-10-20 22:38:20 Chart #11 has tagged chart #3 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #11 has tagged chart #3 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #11 has tagged chart #3 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 CLZ6-NYMEX [CBV] Daily #8 | Reloading chart. | 2016-10-20 22:38:20 NGX6-NYMEX [CBV] Daily #12 | Reloading chart. | 2016-10-20 22:38:20 Chart #12 has tagged chart #2 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #12 has tagged chart #6 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #12 has tagged chart #2 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #12 has tagged chart #6 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #12 has tagged chart #2 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 Chart #12 has tagged chart #6 for full recalculation. Chartbook: Primary.cht | 2016-10-20 22:38:20 NGX6-NYMEX [CBV] 60 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:23 CLZ6-NYMEX [CBV] 30 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:23 ZSX6-CBOT [CBV] 30 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:23 6BZ6-CME [CBV] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Primary.cht | 2016-10-20 22:38:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 63304 | 2016-10-20 22:38:23 Socket (6) | Connected. | 2016-10-20 22:38:23 Rithmic Trading | Connected to server. | 2016-10-20 22:38:23 Rithmic Trading | Sending Encoding Request to server | 2016-10-20 22:38:23 Rithmic Trading | Setting DTC Encoding to Binary | 2016-10-20 22:38:23 Rithmic Trading | Sending logon request message. | 2016-10-20 22:38:23 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-10-20 22:38:23 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\MAIN-Rithmic\Rim\Rithmic.log | 2016-10-20 22:38:23 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-10-20 22:38:23 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-10-20 22:38:25 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-10-20 22:38:25 Rithmic Trading | Received logon response. | 2016-10-20 22:38:25 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-10-20 22:38:25 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-10-20 22:38:25 Rithmic Trading | Successfully connected. IB='AMP'. | 2016-10-20 22:38:25 Rithmic Trading | Trading is supported. | 2016-10-20 22:38:25 Rithmic Trading | Order cancel and replace is supported. | 2016-10-20 22:38:25 Rithmic Trading | Connected to data and trading server. | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: CLZ6-NYMEX. ID: 1 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: CLZ6-NYMEX. ID: 1 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLZ6-NYMEX | 2016-10-20 22:38:25 Intraday data recording state for symbol CLZ6-NYMEX is set to download 'Pending'. | 2016-10-20 22:38:25 Market data subscription status is not known while delaying historical data download for symbol: CLZ6-NYMEX | 2016-10-20 22:38:25 Delaying start of download for CLZ6-NYMEX | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: NQZ6-CME. ID: 2 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: NQZ6-CME. ID: 2 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ6-CME | 2016-10-20 22:38:25 Intraday data recording state for symbol NQZ6-CME is set to download 'Pending'. | 2016-10-20 22:38:25 Market data subscription status is not known while delaying historical data download for symbol: CLZ6-NYMEX | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: ZSX6-CBOT. ID: 3 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: ZSX6-CBOT. ID: 3 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZSX6-CBOT | 2016-10-20 22:38:25 Intraday data recording state for symbol ZSX6-CBOT is set to download 'Pending'. | 2016-10-20 22:38:25 Market data subscription status is not known while delaying historical data download for symbol: CLZ6-NYMEX | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: GCZ6-COMEX. ID: 4 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: GCZ6-COMEX. ID: 4 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCZ6-COMEX | 2016-10-20 22:38:25 Intraday data recording state for symbol GCZ6-COMEX is set to download 'Pending'. | 2016-10-20 22:38:25 Market data subscription status is not known while delaying historical data download for symbol: CLZ6-NYMEX | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: 6BZ6-CME. ID: 5 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: 6BZ6-CME. ID: 5 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6BZ6-CME | 2016-10-20 22:38:25 Intraday data recording state for symbol 6BZ6-CME is set to download 'Pending'. | 2016-10-20 22:38:25 Delaying start of download for CLZ6-NYMEX | 2016-10-20 22:38:25 Rithmic Trading | Starting real-time market data updates for: NGX6-NYMEX. ID: 6 | 2016-10-20 22:38:25 Rithmic Trading | Requesting security definition data for: NGX6-NYMEX. ID: 6 | 2016-10-20 22:38:25 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGX6-NYMEX | 2016-10-20 22:38:25 Intraday data recording state for symbol NGX6-NYMEX is set to download 'Pending'. | 2016-10-20 22:38:25 HD Request # 8 | Downloading Intraday chart data for CLZ6-NYMEX to the file CLZ6-NYMEX.scid. Service: nymex | 2016-10-20 22:38:25 HD Request # 8 | Download start date-time: 2016-10-20 22:37:48.000 | 2016-10-20 22:38:25 HD Request # 8 | Using server: ds6.sierracharts.com port 10149 | 2016-10-20 22:38:25 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-10-20 22:38:25 Socket (7) | Connected. | 2016-10-20 22:38:25 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:25 * HD Request # 8 | Sending historical data logon request message. | 2016-10-20 22:38:25 HD Request # 8 | Requesting Intraday data. Start date-time: 2016-10-20 22:37:48. Record interval: 1. Symbol: CLZ16 | 2016-10-20 22:38:25 HD Request # 8 | Decompressing data. | 2016-10-20 22:38:26 Socket (7) | Shutdown and closed. | 2016-10-20 22:38:26 The network socket for historical data has been closed. | 2016-10-20 22:38:26 HD Request # 8 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLZ6-NYMEX | 2016-10-20 22:38:26 HD Request # 8 | Intraday download COMPLETE for CLZ6-NYMEX. Completion time: 0s. Unique request ID: 7 | 2016-10-20 22:38:26 Removed historical data download ID 7 | 2016-10-20 22:38:26 Real-time Intraday chart data file updates started for CLZ6-NYMEX | 2016-10-20 22:38:26 Intraday chart data file opened for CLZ6-NYMEX | 2016-10-20 22:38:26 Rithmic Trading | Using primary service for historical data for CLZ6-NYMEX | 2016-10-20 22:38:26 Intraday data recording state for symbol CLZ6-NYMEX is set to download 'Pending'. | 2016-10-20 22:38:26 Delaying start of download for CLZ6-NYMEX | 2016-10-20 22:38:26 Delaying start of download for NQZ6-CME | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: RBZ6-NYMEX. ID: 7 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: RBZ6-NYMEX. ID: 7 | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: HOZ6-NYMEX. ID: 8 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: HOZ6-NYMEX. ID: 8 | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: 6EZ6-CME. ID: 9 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: 6EZ6-CME. ID: 9 | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: ZBZ6-CBOT. ID: 10 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: ZBZ6-CBOT. ID: 10 | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: SIZ6-COMEX. ID: 11 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: SIZ6-COMEX. ID: 11 | 2016-10-20 22:38:26 Rithmic Trading | Starting real-time market data updates for: HGZ6-COMEX. ID: 12 | 2016-10-20 22:38:26 Rithmic Trading | Requesting security definition data for: HGZ6-COMEX. ID: 12 | 2016-10-20 22:38:26 HD Request # 9 | Downloading Intraday chart data for CLZ6-NYMEX to the file CLZ6-NYMEX.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 9 | Download start date-time: 2016-10-20 22:37:48.000 | 2016-10-20 22:38:31 HD Request # 9 | Sending historical data request. Start date-time: 2016-10-20 22:37:48. Record interval: 0. Symbol: CLZ6-NYMEX | 2016-10-20 22:38:31 HD Request # 10 | Downloading Intraday chart data for NQZ6-CME to the file NQZ6-CME.scid. Service: cme | 2016-10-20 22:38:31 HD Request # 10 | Download start date-time: 2016-10-20 22:37:29.000 | 2016-10-20 22:38:31 HD Request # 10 | Using server: ds1.sierracharts.com port 10149 | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-10-20 22:38:31 Socket (8) | Connected. | 2016-10-20 22:38:31 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:31 * HD Request # 10 | Sending historical data logon request message. | 2016-10-20 22:38:31 HD Request # 10 | Requesting Intraday data. Start date-time: 2016-10-20 22:37:29. Record interval: 1. Symbol: NQZ16 | 2016-10-20 22:38:31 HD Request # 9 | Receiving Intraday data for CLZ6-NYMEX starting at 2016-10-20 22:37:48 | 2016-10-20 22:38:31 HD Request # 9 | Timestamp of first Intraday data file record written: 2016-10-20 22:38:05 | 2016-10-20 22:38:31 HD Request # 9 | Received 25 records from 2016-10-20 22:37:48 to 2016-10-20 22:38:30 (42.0 seconds) and wrote 24 records for CLZ6-NYMEX | 2016-10-20 22:38:31 HD Request # 9 | Intraday download COMPLETE for CLZ6-NYMEX. Completion time: 0s. Unique request ID: 13 | 2016-10-20 22:38:31 Removed historical data download ID 13 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for CLZ6-NYMEX | 2016-10-20 22:38:31 Intraday chart data file opened for CLZ6-NYMEX | 2016-10-20 22:38:31 HD Request # 10 | Decompressing data. | 2016-10-20 22:38:31 Socket (8) | Shutdown and closed. | 2016-10-20 22:38:31 The network socket for historical data has been closed. | 2016-10-20 22:38:31 HD Request # 10 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ6-CME | 2016-10-20 22:38:31 HD Request # 10 | Intraday download COMPLETE for NQZ6-CME. Completion time: 0s. Unique request ID: 8 | 2016-10-20 22:38:31 Removed historical data download ID 8 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for NQZ6-CME | 2016-10-20 22:38:31 Intraday chart data file opened for NQZ6-CME | 2016-10-20 22:38:31 Rithmic Trading | Using primary service for historical data for NQZ6-CME | 2016-10-20 22:38:31 Intraday data recording state for symbol NQZ6-CME is set to download 'Pending'. | 2016-10-20 22:38:31 HD Request # 11 | Downloading Intraday chart data for NQZ6-CME to the file NQZ6-CME.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 11 | Download start date-time: 2016-10-20 22:37:29.000 | 2016-10-20 22:38:31 HD Request # 11 | Sending historical data request. Start date-time: 2016-10-20 22:37:29. Record interval: 0. Symbol: NQZ6-CME | 2016-10-20 22:38:31 HD Request # 12 | Downloading Intraday chart data for ZSX6-CBOT to the file ZSX6-CBOT.scid. Service: cbot | 2016-10-20 22:38:31 HD Request # 12 | Download start date-time: 2016-10-20 22:36:58.000 | 2016-10-20 22:38:31 HD Request # 12 | Using server: ds6.sierracharts.com port 10149 | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-10-20 22:38:31 Socket (9) | Connected. | 2016-10-20 22:38:31 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:31 * HD Request # 12 | Sending historical data logon request message. | 2016-10-20 22:38:31 HD Request # 12 | Requesting Intraday data. Start date-time: 2016-10-20 22:36:58. Record interval: 1. Symbol: ZSX16 | 2016-10-20 22:38:31 HD Request # 11 | Receiving Intraday data for NQZ6-CME starting at 2016-10-20 22:37:29 | 2016-10-20 22:38:31 HD Request # 11 | Timestamp of first Intraday data file record written: 2016-10-20 22:38:10 | 2016-10-20 22:38:31 HD Request # 11 | Received 6 records from 2016-10-20 22:37:29 to 2016-10-20 22:38:23 (54.0 seconds) and wrote 3 records for NQZ6-CME | 2016-10-20 22:38:31 HD Request # 11 | Intraday download COMPLETE for NQZ6-CME. Completion time: 0s. Unique request ID: 14 | 2016-10-20 22:38:31 Removed historical data download ID 14 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for NQZ6-CME | 2016-10-20 22:38:31 Intraday chart data file opened for NQZ6-CME | 2016-10-20 22:38:31 HD Request # 12 | Decompressing data. | 2016-10-20 22:38:31 Socket (9) | Shutdown and closed. | 2016-10-20 22:38:31 The network socket for historical data has been closed. | 2016-10-20 22:38:31 HD Request # 12 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZSX6-CBOT | 2016-10-20 22:38:31 HD Request # 12 | Intraday download COMPLETE for ZSX6-CBOT. Completion time: 0s. Unique request ID: 9 | 2016-10-20 22:38:31 Removed historical data download ID 9 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for ZSX6-CBOT | 2016-10-20 22:38:31 Intraday chart data file opened for ZSX6-CBOT | 2016-10-20 22:38:31 Rithmic Trading | Using primary service for historical data for ZSX6-CBOT | 2016-10-20 22:38:31 Intraday data recording state for symbol ZSX6-CBOT is set to download 'Pending'. | 2016-10-20 22:38:31 HD Request # 13 | Downloading Intraday chart data for ZSX6-CBOT to the file ZSX6-CBOT.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 13 | Download start date-time: 2016-10-20 22:36:58.000 | 2016-10-20 22:38:31 HD Request # 13 | Sending historical data request. Start date-time: 2016-10-20 22:36:58. Record interval: 0. Symbol: ZSX6-CBOT | 2016-10-20 22:38:31 HD Request # 14 | Downloading Intraday chart data for GCZ6-COMEX to the file GCZ6-COMEX.scid. Service: comex | 2016-10-20 22:38:31 HD Request # 14 | Download start date-time: 2016-10-20 22:37:55.000 | 2016-10-20 22:38:31 HD Request # 14 | Using server: ds1.sierracharts.com port 10149 | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-10-20 22:38:31 Requesting market depth updates for: 6BZ6-CME if supported. | 2016-10-20 22:38:31 Requesting market depth updates for: CLZ6-NYMEX if supported. | 2016-10-20 22:38:31 Requesting market depth updates for: GCZ6-COMEX if supported. | 2016-10-20 22:38:31 Requesting market depth updates for: NGX6-NYMEX if supported. | 2016-10-20 22:38:31 Requesting market depth updates for: NQZ6-CME if supported. | 2016-10-20 22:38:31 Socket (10) | Connected. | 2016-10-20 22:38:31 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:31 * HD Request # 14 | Sending historical data logon request message. | 2016-10-20 22:38:31 HD Request # 13 | Receiving Intraday data for ZSX6-CBOT starting at 2016-10-20 22:36:58 | 2016-10-20 22:38:31 HD Request # 13 | Received 2 records from 2016-10-20 22:36:58 to 2016-10-20 22:36:58 (0.0 seconds) and wrote 0 records for ZSX6-CBOT | 2016-10-20 22:38:31 HD Request # 13 | Intraday download COMPLETE for ZSX6-CBOT. Completion time: 0s. Unique request ID: 15 | 2016-10-20 22:38:31 Removed historical data download ID 15 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for ZSX6-CBOT | 2016-10-20 22:38:31 Intraday chart data file opened for ZSX6-CBOT | 2016-10-20 22:38:31 HD Request # 14 | Requesting Intraday data. Start date-time: 2016-10-20 22:37:55. Record interval: 1. Symbol: GCZ16 | 2016-10-20 22:38:31 HD Request # 14 | Decompressing data. | 2016-10-20 22:38:31 Socket (10) | Shutdown and closed. | 2016-10-20 22:38:31 The network socket for historical data has been closed. | 2016-10-20 22:38:31 HD Request # 14 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCZ6-COMEX | 2016-10-20 22:38:31 HD Request # 14 | Intraday download COMPLETE for GCZ6-COMEX. Completion time: 0s. Unique request ID: 10 | 2016-10-20 22:38:31 Removed historical data download ID 10 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for GCZ6-COMEX | 2016-10-20 22:38:31 Intraday chart data file opened for GCZ6-COMEX | 2016-10-20 22:38:31 Rithmic Trading | Using primary service for historical data for GCZ6-COMEX | 2016-10-20 22:38:31 Intraday data recording state for symbol GCZ6-COMEX is set to download 'Pending'. | 2016-10-20 22:38:31 HD Request # 15 | Downloading Intraday chart data for GCZ6-COMEX to the file GCZ6-COMEX.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 15 | Download start date-time: 2016-10-20 22:37:55.000 | 2016-10-20 22:38:31 HD Request # 15 | Sending historical data request. Start date-time: 2016-10-20 22:37:55. Record interval: 0. Symbol: GCZ6-COMEX | 2016-10-20 22:38:31 HD Request # 16 | Downloading Intraday chart data for 6BZ6-CME to the file 6BZ6-CME.scid. Service: cme | 2016-10-20 22:38:31 HD Request # 16 | Download start date-time: 2016-10-20 22:37:25.000 | 2016-10-20 22:38:31 HD Request # 16 | Using server: ds6.sierracharts.com port 10149 | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-10-20 22:38:31 Socket (11) | Connected. | 2016-10-20 22:38:31 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:31 * HD Request # 16 | Sending historical data logon request message. | 2016-10-20 22:38:31 HD Request # 16 | Requesting Intraday data. Start date-time: 2016-10-20 22:37:25. Record interval: 1. Symbol: 6BZ16 | 2016-10-20 22:38:31 HD Request # 15 | Receiving Intraday data for GCZ6-COMEX starting at 2016-10-20 22:37:55 | 2016-10-20 22:38:31 HD Request # 15 | Timestamp of first Intraday data file record written: 2016-10-20 22:37:55 | 2016-10-20 22:38:31 HD Request # 15 | Received 133 records from 2016-10-20 22:37:55 to 2016-10-20 22:38:31 (36.0 seconds) and wrote 132 records for GCZ6-COMEX | 2016-10-20 22:38:31 HD Request # 15 | Intraday download COMPLETE for GCZ6-COMEX. Completion time: 0s. Unique request ID: 16 | 2016-10-20 22:38:31 Removed historical data download ID 16 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for GCZ6-COMEX | 2016-10-20 22:38:31 Intraday chart data file opened for GCZ6-COMEX | 2016-10-20 22:38:31 HD Request # 16 | Decompressing data. | 2016-10-20 22:38:31 Socket (11) | Shutdown and closed. | 2016-10-20 22:38:31 The network socket for historical data has been closed. | 2016-10-20 22:38:31 HD Request # 16 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BZ6-CME | 2016-10-20 22:38:31 HD Request # 16 | Intraday download COMPLETE for 6BZ6-CME. Completion time: 0s. Unique request ID: 11 | 2016-10-20 22:38:31 Removed historical data download ID 11 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for 6BZ6-CME | 2016-10-20 22:38:31 Intraday chart data file opened for 6BZ6-CME | 2016-10-20 22:38:31 Rithmic Trading | Using primary service for historical data for 6BZ6-CME | 2016-10-20 22:38:31 Intraday data recording state for symbol 6BZ6-CME is set to download 'Pending'. | 2016-10-20 22:38:31 HD Request # 17 | Downloading Intraday chart data for 6BZ6-CME to the file 6BZ6-CME.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 17 | Download start date-time: 2016-10-20 22:37:25.000 | 2016-10-20 22:38:31 HD Request # 17 | Sending historical data request. Start date-time: 2016-10-20 22:37:25. Record interval: 0. Symbol: 6BZ6-CME | 2016-10-20 22:38:31 HD Request # 18 | Downloading Intraday chart data for NGX6-NYMEX to the file NGX6-NYMEX.scid. Service: nymex | 2016-10-20 22:38:31 HD Request # 18 | Download start date-time: 2016-10-20 22:37:39.000 | 2016-10-20 22:38:31 HD Request # 18 | Using server: ds1.sierracharts.com port 10149 | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-10-20 22:38:31 Socket (12) | Connected. | 2016-10-20 22:38:31 Setting HD DTC Encoding to Binary VLS | 2016-10-20 22:38:31 * HD Request # 18 | Sending historical data logon request message. | 2016-10-20 22:38:31 HD Request # 17 | Receiving Intraday data for 6BZ6-CME starting at 2016-10-20 22:37:25 | 2016-10-20 22:38:31 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-10-20 22:38:19 | 2016-10-20 22:38:31 HD Request # 17 | Received 7 records from 2016-10-20 22:37:25 to 2016-10-20 22:38:19 (54.0 seconds) and wrote 6 records for 6BZ6-CME | 2016-10-20 22:38:31 HD Request # 17 | Intraday download COMPLETE for 6BZ6-CME. Completion time: 0s. Unique request ID: 17 | 2016-10-20 22:38:31 Removed historical data download ID 17 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for 6BZ6-CME | 2016-10-20 22:38:31 Intraday chart data file opened for 6BZ6-CME | 2016-10-20 22:38:31 HD Request # 18 | Requesting Intraday data. Start date-time: 2016-10-20 22:37:39. Record interval: 1. Symbol: NGX16 | 2016-10-20 22:38:31 HD Request # 18 | Decompressing data. | 2016-10-20 22:38:31 Socket (12) | Shutdown and closed. | 2016-10-20 22:38:31 The network socket for historical data has been closed. | 2016-10-20 22:38:31 HD Request # 18 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGX6-NYMEX | 2016-10-20 22:38:31 HD Request # 18 | Intraday download COMPLETE for NGX6-NYMEX. Completion time: 0s. Unique request ID: 12 | 2016-10-20 22:38:31 Removed historical data download ID 12 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for NGX6-NYMEX | 2016-10-20 22:38:31 Intraday chart data file opened for NGX6-NYMEX | 2016-10-20 22:38:31 Rithmic Trading | Using primary service for historical data for NGX6-NYMEX | 2016-10-20 22:38:31 Intraday data recording state for symbol NGX6-NYMEX is set to download 'Pending'. | 2016-10-20 22:38:31 HD Request # 19 | Downloading Intraday chart data for NGX6-NYMEX to the file NGX6-NYMEX.scid. Service: rim | 2016-10-20 22:38:31 HD Request # 19 | Download start date-time: 2016-10-20 22:37:39.000 | 2016-10-20 22:38:31 HD Request # 19 | Sending historical data request. Start date-time: 2016-10-20 22:37:39. Record interval: 0. Symbol: NGX6-NYMEX | 2016-10-20 22:38:31 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-10-20 22:38:31 HD Request # 19 | Receiving Intraday data for NGX6-NYMEX starting at 2016-10-20 22:37:39 | 2016-10-20 22:38:31 HD Request # 19 | Received 1 record from 2016-10-20 22:37:39 to 2016-10-20 22:37:39 (0.0 seconds) and wrote 0 records for NGX6-NYMEX | 2016-10-20 22:38:31 HD Request # 19 | Intraday download COMPLETE for NGX6-NYMEX. Completion time: 0s. Unique request ID: 18 | 2016-10-20 22:38:31 Removed historical data download ID 18 | 2016-10-20 22:38:31 Real-time Intraday chart data file updates started for NGX6-NYMEX | 2016-10-20 22:38:31 Intraday chart data file opened for NGX6-NYMEX | 2016-10-20 22:38:31 Opened cached Intraday file: C:\SierraChart\MAIN-Rithmic\Data\CLZ6-NYMEX.scid | 2016-10-20 22:38:37 Opened cached Intraday file: C:\SierraChart\MAIN-Rithmic\Data\GCZ6-COMEX.scid | 2016-10-20 22:38:37 Opened cached Intraday file: C:\SierraChart\MAIN-Rithmic\Data\NQZ6-CME.scid | 2016-10-20 22:38:47 |
[2016-10-21 04:00:49] |
Sadly we realize the reason for this problem. The server-side OCO orders are not being passed through to the Rithmic API. We just sent this message over to Rithmic now about this: As you know Sierra Chart has used the R API + for about a couple of years now. The only thing used in that API is OCO orders. Although it has just come to our attention that since the beginning of July, the OCO orders have not been used through the API but yet brokers have been paying for this feature. The reason this happened is that there were some changes that were made that were never actually compiled into the external bridge program which interfaces to the API because of the problems we encountered compiling the bridge program which uses your API. This is one reason why we do not like API components. There was an unresolved conflict which was difficult to resolve due to an incompatibility and we still have yet to resolve it. This is one reason why we dislike Rithmic. It is always a struggle dealing with these external API components. We were not even aware that effectively the OCO orders had gotten disabled due to the changes and the failure to compile the bridge program due to the conflict. We recommend your broker changes your account over to CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-21 04:03:14
[2016-10-21 04:04:52] |
This further only strengthens the need for a common communication protocol which is the DTC protocol: https://dtcprotocol.org Or the FIX protocol. And we cannot even quickly resolve this problem either. We plan to do some more work with the Rithmic API, in about a couple of weeks but is not something we can just simply resolve immediately at this moment in time. These external API components are nothing but trouble: Sierra Chart Does not Support External Service API Components The intention of sending the message to Rithmic is so that the brokers can get a credit for what they were paying for. And once again we want to point out that the Sierra Chart order confirmations always made it very clear that OCO orders were not supported on the server side when submitting the order. This is why it is important to pay attention to those confirmations. All these months no one ever brought this to our attention that the order confirmation was in conflict with the setting to use server-side OCO orders with Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-21 04:08:26
[2016-10-21 04:12:43] |
This is from our help topic 76 which we link to above: It is routine with API components where we have had various compiling and linking problems with building our software due to conflicts and incompatibilities with the library files of an API component. We may be forced to use particular DLL files and other components which may create new sets of problems. All of this is completely eliminated by not using an API component.
This is the reason for the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-21 04:25:55] |
Actually we came up with a simple solution to reenable the Server-side OCO orders when using Rithmic. We will get this out tomorrow. Update: We released the change in the second revision of 1476. Update Sierra Chart following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate We were not able to test it though. You can tell if server-side OCO is being used based upon the order confirmations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-21 04:38:13
