Date/Time: Fri, 10 Jan 2025 22:54:12 +0000
Buy side contracts are NOT being displayed when using DOM!!!
View Count: 709
[2016-10-18 13:09:15] |
User246578 - Posts: 17 |
Hi there, DOM is not showing buy side contracts??? I'm using Rithmic data feed, and contracts are showing going Rithmic alone. Thank you. Lev |
[2016-10-18 17:29:46] |
We are not sure what you mean by "buy side contracts". Possibly you are referring to market depth data. In this case make sure the Bid Size column is added. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
