Date/Time: Fri, 10 Jan 2025 23:06:17 +0000
Sierra and Gain
View Count: 860
[2016-10-17 20:23:11]
TIM - Posts: 16
Hello, I am using Sierra to much of my liking in the last few years.
I am now having a problem with OEC/Gain. I can t modify my bracket orders, which is strange. In the Gain platform I run on an execution computer I can do it stress free.
Can you help me?
Thank you, my best regards.
Tim
[2016-10-17 22:43:33]
We tested this and saw no problem.
However, what we want you to do is disable Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders.
Try submitting a new order with Attached Orders and then you should be able to modify them.
Date Time Of Last Edit: 2016-10-17 22:44:18
[2016-10-18 07:23:16]
TIM - Posts: 16
Hello, the problem still persists, now I can t even manage orders of positions in the system. But to be frank that is not a solution, server side orders are a MUST.
error: Text: Allocation Blocks is not allowed for a non wash account type
I tried disconnecting and reconnecting from the trade account. Now that earlier error is gone. I can now submit orders to the account. But when I try to manage those orders, error comes again:
error: order modification failed | order modification reject. text: account information does not match original
Can t cancel the order, from charts or Orders and Positions.
: ( Not a happy camper right now.
My best regards,
Tim
[2016-10-18 08:01:51]
The problem is you mistakenly activated the account allocation for orders feature. You need to disable that as explained here:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#DisablingUseOfAccountAllocationForOrders
The name of the option is "Use Account Allocation".
[2016-10-18 08:24:17]
TIM - Posts: 16
It worked!
Thank you very much for this solution. Everything works as expected. Order submitting, modification, the whole deal.
My best regards,
Tim
