Date/Time: Fri, 10 Jan 2025 22:53:39 +0000
Bid/Ask lines on last bar
View Count: 812
[2016-10-17 19:52:03] |
User367875 - Posts: 2 |
Is the option to put the bid/ask lines on the last bar gone? I can't find it under graphic settings anymore (v. 1473) and they are stuck on the right side of the screen where they are pretty useless.
[2016-10-17 22:18:06] |
No. This is under Global Settings >> Graphics Settings >> Other.
[2016-10-17 22:45:38] |
Ok, found it. Thank you very much.
