Date/Time: Fri, 10 Jan 2025 22:50:23 +0000
Candles stopped drawing, but price is updating on the right side
View Count: 860
[2016-10-17 17:56:23] |
User573153 - Posts: 1 |
Hello, I am looking at the NAS100 and the candle bars stopped drawing, but the real-time price is moving on the vertical on the right side. I set the chart time period to 8:30 to 15:00. The time is not right to the actual time. I don't know how to fix this.
sierra.screen.nas100.JPG / V - Attached On 2016-10-17 17:53:30 UTC - Size: 192.73 KB - 271 views |
[2016-10-17 18:29:36] |
You need to set the time zone correctly: http://www.sierrachart.com/index.php?page=doc/TimeZone.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
