Date/Time: Fri, 10 Jan 2025 23:03:28 +0000
Graphics Setting
View Count: 636
[2016-10-17 17:08:55] |
User104854 - Posts: 456 |
Hi. I have the Global Graphics settings pretty dialed in with what I want. I use them on every chartbook that I have. On each chartbook I would like to change the candlestick colors only. If I go into the individual Chart Graphics Settings it seems as if I have to go all or nothing with the Global Settings. Is there a way to use the global settings but change just one aspect of the chart like the candlestick colors? Thanks. |
[2016-10-17 18:01:33] |
No. This is not supported.
