Date/Time: Sat, 11 Jan 2025 00:49:54 +0000
TF
View Count: 805
[2016-10-17 12:56:26] |
AKR - Posts: 523 |
Hello, do I need to activate ICE to get TF RT data = 115$ only for that? If I activate the SC RT feed and take full CME group without market depth. Can I then access the market depth through my broker? (AMP, TTnet) thx! |
[2016-10-17 16:34:03] |
Yes.If I activate the SC RT feed and take full CME group without market depth. Can I then access the market depth through my broker? (AMP, TTnet) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-18 06:52:36] |
AKR - Posts: 523 |
OK, I see. Actually it might help switching from TTnet to Rithmic or CQG because that would (as I understand AMP) include also TF. The reason I did decide for TTnet was Eurex which is not important right now. Which of those two would you prefer? My needs are: ES, NQ, TF real time data and historical tick data. I do need proper volumes but 100% correct bid/ask is not a must. ES also marke depth. And I Need Tick and A/D lines for NYSE - but I think that I have with SC anyway. Is there a need for the SC RT feed in any of both Options considering my Needs? Is there any reason in any of those two Options why I would Need the SC license directly from you and not via AMP (I do have it directly so far but honestly dont exactly remember the reason why I dedided for that - can it be the SC real time feed? ah but I see that Price right now is more or less the same, right)? Thanks! Date Time Of Last Edit: 2016-10-18 06:55:27
[2016-10-18 17:38:27] |
No matter which trading platform service you use, you will have to pay the ICE exchange fee. We recommend using CQG. In this case you do not you need to use the Sierra Chart Exchange Data Feed. Sierra Chart pricing can be found here: http://www.sierrachart.com/index.php?page=doc/Packages.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-19 06:08:32] |
AKR - Posts: 523 |
Now that I have read your Info on the different Feeds in the meantime. It seems with Service pack 5 (which I am on) in both cases I would have historical tick by tick data without Need of SC feed. Why do you prefer CQG, from my guts Feeling I would have decided for Rithmic. thx again! Was off trading for a year and again find out that this is such a great Software! |
[2016-10-19 17:07:11] |
CQG is easier for us to support compared to Rithmic.
