Date/Time: Sat, 11 Jan 2025 01:03:00 +0000
background color between two study lines
View Count: 3135
[2016-10-17 12:55:44]
User170575 - Posts: 221
Good morning,
What is the study to use to change the background color between two study lines? In other words
change the background color between two moving averages?
Many thanks,
Cj
[2016-10-17 18:07:06]
Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#FillingArea
[2016-10-17 19:27:28]
I must be missing something--cant get it to fill--here is an image of the settings---thanks again
imagefill.jpg / V - Attached On 2016-10-17 19:26:03 UTC - Size: 109.3 KB - 472 views
[2016-10-18 16:23:25]
Here is a snapshot of my settings on the Study Subgraph Reference and Horizontal Lines. I have gone through your instructions multiple times and just cant seem to make any headway.
Comments appreciated,
Cj
imagefill subgraphreference settings and inputs.jpg / V - Attached On 2016-10-18 16:20:30 UTC - Size: 78.59 KB - 460 views
imagefill subgraphreference subgraph setting.jpg / V - Attached On 2016-10-18 16:20:47 UTC - Size: 94.87 KB - 422 views
imagefill hor. lines subgraph settings.jpg / V - Attached On 2016-10-18 16:20:59 UTC - Size: 101.54 KB - 386 views
imagefill hor. lines setting and inputs.jpg / V - Attached On 2016-10-18 16:21:21 UTC - Size: 94.52 KB - 398 views
[2016-10-18 19:02:01]
Just give us until later today to rewrite the documentation for this which will make it more clear how to do this.
[2016-10-18 19:14:50]
you guys are the best
[2016-10-19 01:47:54]
Here are the revised instructions for this:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#FillingAreaDifferentStudies
This should be much more clear. Be sure to reload the page in your web browser for the updated content.
[2016-10-19 12:44:32]
many thanks---works great
[2016-10-20 14:25:45]
Many thanks --- really cool---but is there a way to out the chart bar over the fill?
http://www.sierrachart.com/image.php?Image=1476973457898.png
[2016-10-20 17:53:24]
Yes. This is explained at step 6 in the instructions we linked to. You need to enable this option:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DisplayStudyUnderMainPriceGraph
Date Time Of Last Edit: 2016-10-20 17:54:12
