Date/Time: Sat, 11 Jan 2025 02:16:12 +0000
VbP on dom
View Count: 1061
[2016-10-17 12:29:15]
User560062 - Posts: 100
is there a way to have the % that went on bid/ask on the dom and also the total volume as 1 piece of text. Currently you can only either see bid/ask percentages or just the total volume. Is it possible to have both?
e.g.
if we have total volume of 10000 at a price... and 60% went on bid (ie bid is dominant side)
can we have the percentage of the dominant side ie: 60%, 10000
thank you so much.
[2016-10-17 16:31:40]
This can be done for an additional cost of 35-50 USD.
Please do not argue with us about the cost. Sierra Chart is offered very cheap and you are not a direct customer of ours and you are consuming a lot of expensive support. There simply is a cost for this. Take it or leave it.
Date Time Of Last Edit: 2016-10-17 16:31:55
[2016-10-27 15:41:58]
I understand that this can be done by you but I am asking to see if I could do it myself. Is there a way to override the VbP study to change the "display in volume bars" property to something custom. Reason I am asking is that I'd like to be able to combine for example, dominant side %, delta difference and volume in 1 piece of text. Unfortunately sierra doesn't allow to add more than 1 selection for the text to be displayed.
thanks for understanding.
[2016-10-27 16:38:46]
No this is not possible. We would have to add the capability to choose what particular items to include as text on each volume bar. It will be fully configurable.
The fastest solution is just for us to add this one right now:
[2016-10-29 14:33:10]
Yes that would be great.
Thank you
[2016-10-30 23:19:01]
We have said there is an associated cost.
Date Time Of Last Edit: 2016-10-31 00:22:56
