Date/Time: Fri, 10 Jan 2025 22:59:28 +0000
Version 1473, Saved DTS configuration not funtional
View Count: 754
[2016-10-17 06:27:53] |
User567294 - Posts: 47 |
when I try to save DTS config, and load the saved one, it show: invalid saved setting and format. how to solve this? thanks rex. |
[2016-10-17 08:23:25] |
On this page: https://www.sierrachart.com/index.php?page=doc/Whats_New.php It says: The Data/Trade Service Settings window service settings Load and Save functionality is now functional again since being disabled in version 1464 but existing saved named settings will no longer restore the previously saved service settings. New named settings will have to be resaved.
