Date/Time: Sun, 20 Sep 2026 12:44:52 +0000
Charts keep re-loading endmessly
View Count: 3111
[2016-10-16 06:28:08]
Dom7364 - Posts: 258
Any idea what my charts in my chartbook keep loading the same contract over and over again? Generally speaking I have a chart book which has become unusable as it is so slow, but not sure what is causing the issue as it slows everything down and freezes the whole of SC. How can I debug to know? I am not even connected to the datafeed and still, all sheets keeping reloading again and again the last contract.
Any help much appreciated, thank you.
Date Time Of Last Edit: 2016-10-16 07:18:38
[2016-10-16 07:18:00]
Provide a copy of the Message Log by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
[2016-10-16 07:21:47]
Reading Internal Order ID file. | 2016-10-16 08:19:02
Reading Trade Orders file. | 2016-10-16 08:19:02
Reading Trade Positions file. | 2016-10-16 08:19:02
Software version: 1473 | 2016-10-16 08:19:02
Uses New Spreadsheets | 2016-10-16 08:19:02
Usage end date: 2017-02-08 | 2016-10-16 08:19:02
Enabled for: Advanced Features. | 2016-10-16 08:19:02
Enabled for: Advanced Features 2. | 2016-10-16 08:19:02
Enabled for: Sierra Chart Historical Data Service. | 2016-10-16 08:19:02
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-10-16 08:19:02
Current selected Data/Trading service: GAIN Capital/OEC | 2016-10-16 08:19:02
Chart Update Interval: 500 | 2016-10-16 08:19:02
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-10-16 08:19:02
2016-10-16 08:19:06 Local computer time | 2016-10-16 08:19:02
2016-10-16 07:19:06 Local computer time in UTC | 2016-10-16 08:19:02
2016-10-16 08:19:06 Local computer time in SC Time Zone | 2016-10-16 08:19:02
2016-10-16 07:19:07 Server time in UTC | 2016-10-16 08:19:02
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-10-16 08:19:02
Program path: C:\SierraChart\ | 2016-10-16 08:19:02
Data Files path: C:\SierraChart\Data\ | 2016-10-16 08:19:02
OS Version Number: 6.1 | 2016-10-16 08:19:02
Locale Setting: C | 2016-10-16 08:19:02
Checking for new symbol settings for oec | 2016-10-16 08:19:02
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-16 08:19:02
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-10-16 08:19:02
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-10-16 08:19:02
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-10-16 08:19:02
Symbol settings are up-to-date for oec | 2016-10-16 08:19:02
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-16 08:19:08
HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-10-16 08:19:09
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-10-16 08:19:12
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-10-16 08:19:12
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-10-16 08:19:12
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-10-16 08:19:12
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-10-16 08:19:12
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-10-16 08:19:12
HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-10-16 08:19:14
HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-10-16 08:19:14
GainCapital FIX Trading socket (5) | Error received in OnConnect while connecting. Windows error code 10060: Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu. | 2016-10-16 08:19:33
GainCapital FIX Trading socket (5) | Shutdown and closed. | 2016-10-16 08:19:33
GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-10-16 08:19:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-10-16 08:19:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-10-16 08:19:33
GAIN Capital/OEC | Disconnected from the trading server. | 2016-10-16 08:19:33
GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-10-16 08:19:33
GAIN Capital/OEC | Disconnected. | 2016-10-16 08:19:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-10-16 08:19:33
File >> Disconnect selected. | 2016-10-16 08:19:35
GAIN Capital/OEC | Disconnected. | 2016-10-16 08:19:35
6BZ6 [C] 5000 Volume #1 | Reloading chart. | 2016-10-16 08:19:39
Notice: The study 'DOM Size for Dom64' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-10-16 08:19:39
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 0.0004 Range #4 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] #8 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] #9 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] #11 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] 1 Day #12 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] 1 Day #12 | Limiting the number of years to download historical data for to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2016-10-16 08:19:39
6BZ6 [CB] 60 Min #13 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [CB] 60 Min #13 | Limiting the number of years to download historical data for to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2016-10-16 08:19:39
Notice: The study 'EngulfingBar_Vline' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-10-16 08:19:39
6BZ6 [C] 60 Min #14 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 10 Min #10 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [CBV] 1 Day #16 | Reloading chart. | 2016-10-16 08:19:39
Failed to get the Advanced Custom Study function address for scsf_ECIAnchorVwap in UserContributedStudies.dll. Error: Windows error code 127: La procédure spécifiée est introuvable. | 2016-10-16 08:19:39 *
6BZ6 [CBV] 1 Day #17 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] #19 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 15 Min #7 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [CV] Weekly #18 | Reloading chart. | 2016-10-16 08:19:39
6BZ6 [C] 15 Min #15 | Reloading chart. | 2016-10-16 08:19:39
Chart #10 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:19:39
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:19:39
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:19:39
Chart #1 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:19:39
Intraday data recording state for symbol 6BZ6 is set to download 'Pending'. | 2016-10-16 08:20:32
HD Request # 2 | Downloading Intraday chart data for 6BZ6 to the file 6BZ6.scid. Service: oec | 2016-10-16 08:20:32
HD Request # 2 | Download start date-time: 2016-10-14 21:59:57.000 | 2016-10-16 08:20:32
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-10-16 08:20:32
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:20:32
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-10-16 08:20:32
Socket (6) | Connected. | 2016-10-16 08:20:32
Setting HD DTC Encoding to Binary VLS | 2016-10-16 08:20:32 *
HD Request # 2 | Sending historical data logon request message. | 2016-10-16 08:20:32
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:20:32
HD Request # 2 | Requesting Intraday data. Start date-time: 2016-10-14 21:59:57. Record interval: 0. Symbol: 6BZ6 | 2016-10-16 08:20:32
HD Request # 2 | Decompressing data. | 2016-10-16 08:20:32
HD Request # 2 | Receiving Intraday data for 6BZ6 starting at 2016-10-14 21:59:57 | 2016-10-16 08:20:32
Socket (6) | Shutdown and closed. | 2016-10-16 08:20:32
The network socket for historical data has been closed. | 2016-10-16 08:20:32
HD Request # 2 | Historical data for 6BZ6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-10-16 08:20:32
HD Request # 2 | Received 2 records from 2016-10-14 21:59:57 to 2016-10-14 21:59:57 (0.0 seconds) and wrote 0 records for 6BZ6 | 2016-10-16 08:20:32
HD Request # 2 | Intraday download COMPLETE for 6BZ6. Completion time: 2s. Unique request ID: 1 | 2016-10-16 08:20:32
Removed historical data download ID 1 | 2016-10-16 08:20:32
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:32
Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:32
HD Request # 3 | Downloading Historical Daily chart data for 6BZ6. Starting date: 2016-10-13. Service: oec | 2016-10-16 08:20:32
HD Request # 3 | Requesting historical Daily data for B6Z16 starting at 2016-10-12 | 2016-10-16 08:20:32
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-10-16 08:20:32
HTTP connection to ds01.ddfplus.com:80 (7) | Connected. | 2016-10-16 08:20:32
HD Request # 3 | Receiving historical Daily data for 6BZ6 starting at 2016-10-13 | 2016-10-16 08:20:32
HD Request # 3 | Writing historical Daily data to the file 6BZ6.dly | 2016-10-16 08:20:32
HD Request # 3 | Received 3 records from 2016-10-13 00:00:00 to 2016-10-14 00:00:00 (2.0 days) and wrote 2 records for 6BZ6 | 2016-10-16 08:20:32
HD Request # 3 | Daily download COMPLETE for 6BZ6. Completion time: 2s. Unique request ID: 2 | 2016-10-16 08:20:32
Removed historical data download ID 2 | 2016-10-16 08:20:32
Chart #10 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:32
Failed to get the Advanced Custom Study function address for scsf_ECIAnchorVwap in UserContributedStudies.dll. Error: Windows error code 127: La procédure spécifiée est introuvable. | 2016-10-16 08:20:32 *
6BZ6 [CV] Weekly #18 | Reloading chart. | 2016-10-16 08:20:32
Chart #1 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:47
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:20:47
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:20:47
6BZ6 [C] #11 | Reloading chart. | 2016-10-16 08:20:47
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:47
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:20:54
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:20:54
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:20:56
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:21:01
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:21:01
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:21:04
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:21:04
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:21:04
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:21:11
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:21:11
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:21:11
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:21:18
6BZ6 [C] 0.0004 Range #6 | Reloading chart. | 2016-10-16 08:21:18
6BZ6 [C] 0.0004 Range #5 | Reloading chart. | 2016-10-16 08:21:18
Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2016-10-16 08:21:23
[2016-10-16 07:42:55]
We are not sure why it is exactly happening but we are fairly certain in your case it is happening because there is a particular study on chart causing this to happen.
Remove the studies one by one from a chart that is reloading to see which one it is.
[2016-10-16 08:19:14]
ok tbut it seems to be doing it on ALL chart within the chartbook, not on only one in particular, and because it keeps loading up, I can't access the studies list, and it won't let me...In fact if I have several chartbooks open, and if I switcj to a different one, the other one seems to be also experiencing freezing and slowness because of the one that causes problem..
Date Time Of Last Edit: 2016-10-16 08:21:31
[2016-10-16 08:42:49]
Restart Sierra Chart and enable the "Safe Mode" option on the Login window.
Does that resolve the problem?
[2016-10-16 09:03:05]
it stops reloading, but still some "flashes" at times and I need to press 10 times or so on OK or APPLY for things to happen, but at least the reload of the contracts has stopped. Is this a mode I can stayon permanently?
[2016-10-16 09:19:36]
We see no reason why you should be clicking 10 times on a button. Once is enough. If Sierra Chart is freezing at times, refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
Check the Message Log to see if there any messages indicating charts are being reloaded . This should not happen any longer.
Continue to use Safe Mode for the time being until we understand the reason for the problem.
[2016-10-16 10:38:10]
me neither, but unless I showed you a video, it is difficult to see what I mean. I click on Studies, then add a study, and click OK and I get an hour glass, screzen flashed and I need to hit OK several times before it eventually applies the study. Strange.
[2016-10-16 12:25:46]
This is because the study is using a lot of CPU time.
Refer to help topic 30 about this:
Also you do not have to press OK several times. Just wait.
[2016-10-18 02:35:30]
We now discovered the reason for the charts reloading. This is resolved in the latest prerelease.
Update with Help >> Download Prerelease.
