Date/Time: Thu, 26 Sep 2024 23:25:24 +0000
Chart Values
View Count: 1356
[2013-07-27 22:57:25] |
Graham - Posts: 44 |
Is it possible for the chart values (OHLC) to be plotted as text on the actual chart itself, in a position I can adjust, rather than having them in a window? Thanks |
[2013-07-28 09:49:20] |
Yes. This is known as the Compact Tool Values window: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-28 14:22:47] |
Sawtooth - Posts: 4092 |
Or you could use 4 instances of the Text Display for Study study.
[2013-07-28 17:14:59] |
Thanks all, cracked it.
