Date/Time: Sat, 11 Jan 2025 00:05:05 +0000
Chart Update Interval
View Count: 981
[2016-10-13 19:27:35] |
Japhro - Posts: 120 |
The default Chart Update Interval is 0, meaning it is a hidden default, can I ask exactly what the default interval is? The reason being, for many charts I do not need to update that quickly, and I would prefer to shift CPU load over to a few fast moving DOMs instead (charts slower or at default DOMs faster than default). It's hard to do this properly without knowing what the default is. Thanks as always - J
[2016-10-14 01:49:51] |
You are referring to the Chart Update Interval setting in a chart itself. Refer to: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
