Date/Time: Fri, 10 Jan 2025 23:42:33 +0000
Chart DOM Columns - Background
View Count: 1346
[2016-10-13 16:45:59] |
User104854 - Posts: 456 |
Hi. I am trying to change the colors of some of the columns on the chart DOM that I have on my chart. I've tried the Graphics Settings - Chart and also the Global Settings and no matter what I do the background stays the same color as the chart. Is there a way to do this? I've provided a screenshot. Thanks. http://www.sierrachart.com/image.php?Image=1476376938807.png |
[2016-10-13 17:46:38] |
Refer to the various color settings documentation here: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php In some cases you need to enable the "Enable" setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-13 17:57:40] |
That did it. Thank you.
