Date/Time: Fri, 10 Jan 2025 23:47:35 +0000
Intraday UK Stocks data
View Count: 905
[2016-10-13 12:11:54] |
ScoTTyBEEE - Posts: 5 |
Hi, If I use the ticker XXX.LS I can get EOD data for UK stock prices. Is there anyway to pay for intraday data as I cannot see which service I would need to purchase? Thanks, Scott. |
[2016-10-13 17:40:36] |
Yes. You can use the Tele-trader Data Service for this: http://www.sierrachart.com/index.php?page=doc/TeleTrader.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-13 18:13:41] |
Thanks for your prompt response. Scott. |
