Date/Time: Fri, 10 Jan 2025 23:50:58 +0000
Automatic symbol change when changing data vendor
View Count: 1017
[2016-10-13 04:23:47] |
Willson - Posts: 176 |
When I copy a chart file from computer A using data vendor A to computer B using data vendor B, I must change the symbol nomenclature for each chart manually. If using many charts this is very time consumming. Is there a way to convert symbols automatically? thanks for help on this. |
[2016-10-13 04:27:47] |
No, there is definitely no way to do this automatically. Unless you were to write a custom study to do this: Advanced Custom Study Interface and Language (ACSIL) Specifically refer to: ACSIL Interface Members - Variables and Arrays: sc.DataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
