Date/Time: Fri, 10 Jan 2025 22:55:35 +0000
Delta alerts
View Count: 1355
[2016-10-12 09:16:03]
User87765 - Posts: 10
Hello, is there any way I can set an alert to sound when delta reaches either + or - a given value on the numbers bars?
If not, can you invent one? thanks :)
[2016-10-12 10:24:20]
Yes. Refer to:
Study/Chart Alerts And Scanning
You will want to set the alert on the Bid Volume versus Ask Volume study.
Date Time Of Last Edit: 2016-10-12 10:24:40
[2016-10-13 12:26:07]
Hello again, I am a complete novice at Excel and I'm struggling to get the syntax right for this. Can anyone help with that?
[2016-10-13 17:31:42]
This is the formula to use:
OR(SG5 < -100, SG5 > 100)
Use this formula with the Bid Volume versus Ask Volume study. This will provide an Alert when the difference between Ask Volume and Bid Volume is greater than 100 or less than -100.
[2016-10-17 18:43:34]
Ok thanks... I require an alert when ask data MINUS bid data is +/- 360 though... is this the above formula? or can you suggest the formula that would work in this instance.
Thanks in advance! :)
[2016-10-17 22:15:45]
Yes of course that is the formula.
Just change the 100s to 360.
