Date/Time: Fri, 10 Jan 2025 22:56:54 +0000
mini sized charts
View Count: 1018
[2016-10-12 04:40:43] |
User376341 - Posts: 37 |
Hi Seeing a feature on Ninja trader platform, a small chart that seems to be detachable and positioned anywhere as attached,only about 2 inches square on screen Does Sierra chart have something similar? J |
mini cl.png / V - Attached On 2016-10-12 04:40:16 UTC - Size: 8.01 KB - 265 views |
[2016-10-12 04:45:33] |
Refer to: Detaching and Attaching Chart Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-12 05:16:28] |
aydex - Posts: 110 |
Thanks, With the slow stochastic study, does it calculate on barclose, please? |
[2016-10-12 05:51:22] |
No it is continuously calculated.
[2016-10-12 05:56:31] |
I shall assume that there is no option to change that. Another question. Is there a "Time and Sales" output that shows the Market's time eg. HH:MM:SS, not from local computer, but forwarded from exchange, please |
[2016-10-12 10:25:18] |
Yes, there is no option to currently change the calculation of studies. It might come later. Is there a "Time and Sales" output that shows the Market's time eg. HH:MM:SS, not from local computer, but forwarded from exchange, please Yes. Refer to:Time and Sales Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-18 04:24:17
[2016-10-13 04:31:53] |
How do I remove the black 0.000 pls i have tried using "hidden" for line SG4 in standard macd study see attached |
[2016-10-13 04:37:04] |
That is a Subgraph >>Value Label: Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-13 05:17:08] |
1 I'm probably missing something, but value label looks not enabled in attached actually not seeing "Show option for the Value Label" tickbox 2. Is there a way to "cast a shadow" of the (session) opening bar's range throughout the session, pls 3. And is there a way to position/calculate a 50% horizontal line of that range if you guys got that last one i will be blown away :) |
[2016-10-13 16:52:25] |
1. Does the value box of 0.000 go away when you remove the MACD study from the chart? 2. Use the High/Low for Time Period-Extended study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s246 3. Use Study Subgraphs Average: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-16 22:11:30] |
1. After removal of study, remaining is a similar black box that has current price of the main chart. (value not 0.000) |
[2016-10-17 16:47:05] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-18 03:40:36] |
Just to clarify Question from Sierra Chart Engineering: 1. Does the value box of 0.000 go away when you remove the MACD study from the chart? A After removal of study, remaining is a similar black box that has current price of the main chart. (value not 0.000) image before image: value.PNG image after (screen capture, duration 11 seconds) http://screencast.com/t/LmhQBQMU8 |
[2016-10-18 04:25:28] |
We do not accept videos. When posting an image of a chart, only use the method documented here: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Anyway, we know what the problem is and we will resolve this in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-18 04:26:10
