Date/Time: Sat, 11 Jan 2025 00:02:19 +0000
Number bars with Wick
View Count: 1863
[2016-10-11 06:59:51] |
Executor - Posts: 40 |
I have changed my 5 min chart to show volume clusters using number bars, unfortunately I can't figure out how add wicks to number bars, I have added candlestick outline. This does not show candle wicks tho |
[2016-10-12 02:19:06] |
This is supported in version 1472 and higher. Update to the latest prerelease following these instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#InputSettings You will need to set the Open and Close Marker Style Input to Candlestick Outline. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
