Date/Time: Fri, 10 Jan 2025 22:08:26 +0000
Closed Sierra Chart
View Count: 704
[2016-10-10 20:06:31] |
Emoya78 - Posts: 10 |
Hi, I had an order filled with a target and stop order. My internet stopped working and had I had to shut down sierra chart. When I came back online my filled order was closed. If I close Sierra charts down does it close my filled orders? I also got this message before closing... You have open order with your trading service. Do you wish to exit? If these open orders include client-side managed Attached Orders or Trailing stop orders, they will no longer be managed. What exactly does this mean? Date Time Of Last Edit: 2016-10-10 20:44:48
[2016-10-11 04:46:37] |
If I close Sierra charts down does it close my filled orders? This does not make sense. Unless you are referring to Trade Positions?Maybe you are asking whether Sierra Chart is going to cancel Attached Orders when it is closed. The answer to this is no. For additional information about this, refer to: Attached Orders: General Management of Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
