Date/Time: Fri, 10 Jan 2025 21:40:55 +0000
S&P and Dax
View Count: 678
[2016-10-10 16:24:32] |
User131601 - Posts: 2 |
Is it possible to get S&P and Dax real time charts whilst in trial mode? If so which symbols can I use?
[2016-10-10 17:10:59] |
Yes you can use this service: Sierra Chart Real Time and Historical Forex and CFD Data Service The symbols are in File >> Find Symbol >> CFD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
