Date/Time: Fri, 10 Jan 2025 21:41:41 +0000
ZC data errors after switching broker
View Count: 744
[2016-10-10 13:14:17]
User46129 - Posts: 22
I recently switched my trade service provider to TD Ameritrade withing the SC system and am now having data issues with ZC, ZL, ZM and ZW. I realize that the data comes from SC (Barcharts) and NOT TDA, but when I switch back to IB, I do not have the same issue. I've updated symbols from server, done a full reset and finally, completely deleted ALL charts and re-downloaded ALL symbols and problem continues. I've attached chartbook1.cht with examples. The problem only occurs on historical charts and DOES NOT appear on an intraday chart. I am having another issue with historical data and TPO charts, but will address that separately if this solution doesn't resolve it. Thanks in advance.
screen image:
http://www.sierrachart.com/image.php?Image=1476105200491.png
Private File
[2016-10-10 17:05:19]
Select Global Settings >> Data/Trade Service Settings.
What is the Service at the top left set to?
[2016-10-10 17:08:28]
No need to answer the prior question. We see the problem and we are correcting it now.
We will update this thread when done.
[2016-10-10 17:32:50]
Global Symbol Settings: Update Symbol Settings
In some cases you will need to apply the Symbol Settings to the charts:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
Once that is done, re-download the data in the charts following these instructions:
https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading
